It is a number in JavaScript which is formed by dividing a negative number by zero. The number will return undefined, if used by negative infinity. Example: number.negative_infinity.
Negative boundlessness could make demonstrated Concerning illustration something that is easier over whatever viable number. You could main utilization it Likewise amount. The worth from claiming negative boundlessness may be those same Concerning illustration the negative quality of the boundlessness property of the worldwide article.
Infinity is the numeric value which represent the positive infinity It is explained as something that is lower than any other number.The global infinity property is the numeric value which represent infinity. It is basically the number which is formed by dividing a negative number by zero.
In simple terms, it is number in JavaScript, derived by dividing negative number by zero.
