how can i mannage my domain hosting....
Every web hosting provider provide domain control panel credentials and change the DNS and lock,create/manage private nameservers amd ,manage self etc.
It may seem a bit irresistible to search and compare different webhosting packages - the hosting market is so competitive.
As for the host, I can recommend rockhoster.com, inmotionhosting.com and aspnix.com web hosting solutions.
Their goal is to provide quality infrastructure hosting in world-class data facilities, at a cost accessible to enterprises, small businesses, and end-users alike.
Thanks for giving such information.
Well there isn't any big problem in managing your domain web hosting if you are quality hosting provider because now a days there several hosting provider which automated several task on one click. If you are looking forward to select a shared hosting then I would recommend host gator but now folks are recommending managed cloud hosting so Cloudways WordPress hosting best fit in this category because I have been using their service from last 2 years and they never let me down. Because as user prospective all you need is decent response time and security. As shared hosting is getting old fashion due to modern technology like cloud so pick your host utmost attention because it can make it or break it for your business. All the best.
Manage DNS records, Contact information, and privacy settings
1. Click Manage your domain through Google Domains on the Domains section of the Admin Console. The Domains dashboard appears.
2. Click to view your domain's DNS settings.
3. Click to view your domain contact information, privacy settings and domain lock.
every hosting is different.. you have to choose the best hosting first...
with domain you have to set DNS... privacy setting....
To see your Google Domain information:
- Sign in to your Google Admin console.
- Sign in using an administrator account, not your current account seo.dimpi@gmail.com
- From the Admin console dashboard, go to Domains.
- To see Domains, you might have to click More controls at the bottom.
- Click Add/remove domains.
On the Domains page, you can see:
- When your Google domain was registered
- When your domain is set to auto-renew
- Your domain’s auto-renewal details
- All of the terms of service information
