File Transfer Protocol (FTP) is a standard Internet protocol for transmitting files between computers on the Internet over TCP/IP connections.
FTP is a client-server protocol that relies on two communications channels between client and server: a command channel for controlling the conversation and a data channel for transmitting file content.
FTP is a client-server protocol that relies on two communications channels between client and server: a command channel for controlling the conversation and a data channel for transmitting file content. Clients initiate conversations with servers by requesting to download a file. Using FTP, a client can upload, download, delete, rename, move and copy files on a server. A user typically needs to log on to the FTP server, although some servers make some or all of their content available without login, also known as anonymous FTP.
Quote:
Originally Posted by
jameskamroon1
What is FTP?
It's a File Transfer Protocol invented when you probably didn't born yet :)
It was used to transfer files between the server for the decades already, and have been improved few times already: added SSL support and such things, because basically it didn't support any data safety and even require name and password to be sent cleartext :)
You can still use FTP with modern applications because it's common, supported and light-weight
Most modern OS also supports it natively too.
If you think about installing your own FTP server at the VPS you can take a look at this article.
FTP is an acronym for File Transfer Protocol. As the name suggests, FTP is used to transfer files between computers on a network. You can use FTP to exchange files between computer accounts, transfer files between an account and a desktop computer, or access online software archives. Keep in mind, however, that many FTP sites are heavily used and require several attempts before connecting.
Note: You need to use a client that supports secure FTP to transfer files to and from Indiana University's central systems. For more, see At IU, what SSH/SFTP clients are supported and where can I get them?
The File Transfer Protocol (FTP) is a standard network protocol used to transfer computer files between a client and server on a computer network. FTP is built on a client-server model architecture and uses separate control and data connections between the client and the server.
(FTP) abbreviated as File Transfer Protocol a standard network protocol used to transfer computer files between a client and server on a computer network
CertifyGuide – The Ultimate Source of Certification Exam Preparation Guides
The File Transfer Protocol (FTP) is a regular network protocol used to transfer computer files between a customer and server on a computer network.
Method of transferring data files from one computer to another over a network. The most basic way of sending and receiving files over internet, FTP divides files into several segments and assigns a reference number to each one. These segments are transmitted in a sequence which the receiving computer reassembles as an exact copy of the original. FTP also performs automatic error detection and correction in file transfers
FTP is a File Transfer Protocol. It is a protocol which is used to exchange files/documents over the internet. For exchanging or transferring purpose, FTP uses IP protocol to enable exchange/transfer files.
This is a standard network protocol.
File Transfer Protocol, or FTP, is a standard network protocol that is used to transfer computer files between a client and server on a computer network.
File Transfer Protocol (FTP) is the commonly used protocol for exchanging files over the Internet. FTP uses the Internet's TCP/IP protocols to enable data transfer. FTP uses a client-server architecture, often secured with SSL/TLS. FTP promotes sharing of files via remote computers with reliable and efficient data transfer.
