Here is the detailed explanation for you - https://forums.24x7servermanagement....cation-hosting
Hope this will help you. :)
Thanks for this post.
If you are looking for flexible and control owing your hardware afterward colocation is your greatest solution. Colocation has its own benefits including access to exceptional bandwidth, flexibility, improves network reliability and enables siting of information and network tools.
such a useful information you are giving to us we really thankful to you for this kindness you always prove right to us
That's a fairly bare explanation. But I guess it fits. I also think you can , for at least the most part, are able to get specs catered to your needs with a monthly that is a flat fee regardless of the specs. OF course for a low end server it's much cheaper to just rent. But a Mid to high end server the ROR is much better on collocating.
Colocation also provides:
Better connectivity. Colocation data centers have fully redundant network connections ensuring that customers’ business critical applications always run uninterrupted.
Improved network security. Data centers have top-notch network security, including the latest firewalls / IDS systems to detect and prevent unauthorized access to their customers’ systems.
Redundant power supply. Colocation data centers offer power redundancy through a combination of multiple power grids, diesel power generators, double battery backup systems and excellent maintenance practices.
Bursting capability. Colocation centers provide customers with the flexibility to burst to higher bandwidth levels to accommodate their traffic demand without having to make repeat capital investments. Since data spikes are distributed over time across numerous users, bandwidth costs are significantly reduced.
Room for growth. Colocation allows you to expand your infrastructure to fit the needs of your company’s growth without having to take on capital expenditures. If you’re company grows, your IT infrastructure can expand to support it quickly and with less investment.
A step toward cloud migration. If your company is looking at cloud computing in the near future, colocation provides a smooth transition by allowing you to move your equipment to an offsite facility with increased capacity and performance to support business needs while ensuring a smooth cloud transition.
The advantages of Colocation Hosting are given below:
1. Service and support
2. IT management
3. Costs of data centre operations
4. Scaling
5. Security
Some of the benefits of collocation hosting is:-
1. Availability
2. Connectivity
3. Security
4. Stability
5. Predictability
Benefits of Colocation Hosting:
a)Greater amount of bandwidth is available.
b)Colocation hosting is more cost efficient than hosting your own server.
c)Your server is stored in a secure location.
d)Makes necessary upgrades easy to obtain.
e)Room temperatures remain perfect for your equipment.
f)Should you move your business to a new location, your sever does not have to move with you.
g)You have more flexibility and the ability to customize your needs.
h)You have and full control over your server.
The greater amount of bandwidth is available.
Colocation hosting is more cost-efficient than hosting your own server.
Should you move your business to a new location, your server does not have to move with you.
