I bare in my mind two hosts (limeisp.com and hostround.com) which are attractive for me and I want to know which way is better for me to follow?
Taking the advantage of the opportunity I can recommend warez-host.com offshore vps plans.
Use the promo code SAVEON15V to receive 15% lifetime discount for all new VPS purchases.
Could you share your requirements here so that we can assist you the hosting plans for your needs, I would recommend you to check reviews of their services and support. Compare the hosting plans and features then choose your preferred hosting provider.
There are plenty european host whom can satisfy your criteria. Unfortunately, I have never utilised the two hosts you have mentioned, but can recommend hosts such as HostXNow, clouvider, brixly, vmhause, and many more.
Maybe if you include more info such as your budget and VM specs, I can narrow down my reccommendations.
Why not check out UKHost4u and you might consider their services? ;)
Check offers section for great European VPS deals ;)
I wouldn't move from Cloudarion.com for anything, not while it's working as great as now!
Great support, personalized service, and deff recommend.
What is your budget? and what is your location preference?
You can get cheap VPS hosting in Europe starting from as low as EUR 7.99 /month, with VPN enabled and full root access. Every VPS comes with 15-day full money back guarantee.
I think you can find some cheap VPS deals here as well:
https://libertyvps.net/
If you check out qhoster.com you will discover they provide up to 30 server locations and most of them are in Europe.
Please specify, why are they attractive for you? Please share your requirements
You can check https://vikhost.com/vps-ukraine. We have cheap, reliably and with qualified support 24x7.
Hostsailor.com and libertyvps.net deals are worth trying.
Happy to use their service, being one of the first ones to grab their discounted price. The support specialist was very courteous and guided me through the problem I was having setting up SSL for my site.
Host1Plus is an UK based web hosting provider which is a good option.
