Hello
Hope anyone can help.
I have a problem in moving PrestaShop 1.6 from localhost to livehost.
I do this steps:
1- compress PrestaShop files to zip file in localhost
2- export PrestaShop database in localhost to an sql file.
3- move myprestashop zip file to public HTML in live host via FileZilla
4- extract zip file in livehost and path is: public_html/all PrestaShop folder and files
5- went to MySQL databases in cpanel and create database prestashop and user and import prestashop.sql that created in localhost. Then add a user to database with all privileges.
When everything is done, I check the site it shows: "Megamenu need to chmod to 755. This hosting may not be compatible with Mega menu" error. This is the Prestashop mega menu module that I use: https://www.prestashop.com/forums/to...a-menu-module/
What did I do wrong? may I need to change to a new hosting provider?
Thanks and looking for your help
In addition, all other modules work well except this module, it must be a problem of hosting.
Thanks
