It is the process of encoding message in a way that only authorized persons to receive and understand it. Encryption is important as it allows protecting data which you don’t want to access anyone else.
Great excellent. Exactly the same as you guys mentioned above.
Hi!
Thanks for sharing such a great article.
Its my truly pleasure to have this Knowledge.
i heard that in next update Google will add SSL certificate as a mandatory thing for ranking
Need a Developer? | Get Quotes In Under 60 Seconds|Dedicated|$12 Per Hour|100% Satisfaction Guaranteed|24*7|Visit ksoftcloud.com
Secure
Provide end to end encryption that secures the connection between the server and the browser
Prevent hacking
Very fewer chances of a vulnerability
Increase the user trust
Prevent the virus attacks
1. Security. Prevent your website from hacker attacks.
2. Safety. Your website will be trusted by the visitors.
3. Ranking higher. Google ranks higher the website with SSL certificate because HTTPS is a reference factor in search ranking algorithms.
Secure site makes the consumer more comfortable using your website and having HTTPS can also help with your SEO Ranking. If your website isn't secure yet it should be Here's why:
1 Increased Google Ranking: Over 40% of the websites on the first page of Google are HTTPS, which is not a surprise since Google has confirmed that they favor of HTTPS sites.
2 Improved Security: HTTPS protects your users' information and your information from hackers. Keeping everything safer and more secure is simply a better option for everyone.
3 Updated Browser Label: As we tired of talking about Google yet? Will, there is one more thing. As part of their push for a more secure web, Google is also updating their labeling for HTTP sites in Chrome URL bar.
4 Increased Conversion: While users may not have a complete technical understanding of secure connections, they do understand they want a site to be HTTPS.
5 Increased Customer Confidence: With all the buzz about HTTPS going around, more users are specifically looking for a secure connection when visiting a website.
A secure connection gives your customer peace of mind that your website can be trusted and their information is safe.
Because If you do not want your site to be hacked from intruders then you should use ssl in your site. it provide your site security and reliablity so that nobody misuse your site
Main reason to use SSL is to achieve higher search engine ranking position.
five key benefits of using an SSL certificate.
1. SSL Protects Data
SSL, every bit of information is encrypted. While dealing with sensitive data such as IDs, passwords, credit card numbers, etc., SSL helps you protect against the mischievous army of hackers and skimmers.
2. SSL Affirms Your Identity
SSL certificate is to provide authentication to a website
3. Better Search Engine Ranking
4. SSL Helps You Satisfy PCI/DSS Requirements
If you accept online payments, you must know a thing or two about PCI/DSS requirements. To receive online payments, your website must be PCI compliant. Having an SSL certificate installed is one of the 12 primary requirements set by the payment card industry (PCI).
5. SSL Improves Customer Trust
Apart from encryption and authentication, SSL certificates are vital from a customer trust point of view. The easy to identify signs inform the users that the data they send will be secured. And if you’ve installed an OV or EV SSL, they can see your organization’s details.
HostechSupport
24x7 Remote Services
Linux/Windows Server Administration Server Management
Get in touch: support@hostechsuppport.com
Benefits of using an SSL certificate.
With SSL every bit of information is encrypted. sensitive data such as IDs, passwords, credit card numbers, etc., SSL helps you to protect against the mischievous hackers and skimmers.
SSL certificate provide authentication to a website
for online payments PCI/DSS is requird. To receive online payments, website must be PCI compliant. SSL certificate installed is one of the 12 primary requirements set by the payment card industry (PCI).
SSL certificates are vital from a customer trust point of view. The SSlsigns inform the users that the data they send will be secured.
HostechSupport
exactly right...
addition to this Google give importance and prefer in index ranking. This factor count as an keen factor
5 Reasons Why You Need SSL
Encrypt Your Information. The purpose of SSL is to keep sensitive information sent across the Internet encrypted so that only the intended recipient can make use of it. ...
Authentication. ...
Improved SEO Scores. ...
Gain Customer Trust. ...
Protection Against Phishing Attacks.
1.) It authenticates the identity of website.
2.) It encrypts the data and secures the organizational details and location.
3.) It improves the speed of the website.
4.) Customers will see you as a trustworthy brand.
5.) It enhances the search engine ranking for your website.
Any computer in between you and the server can see your credit card numbers, usernames and passwords, and other sensitive information if it is not encrypted with an SSL certificate. When an SSL certificate is used, the information becomes unreadable to everyone except for the server you are sending the information to.
