Results 1 to 11 of 11
    Jul 2018
    199
    how-to-fix-sitemap-issues
    Jun 2018
    1,416
    How To Detect + Fix Sitemap Problems
    Log into Google Search Console.
    Go to the Sitemaps section (Crawl > Sitemaps)
    It will show you the sitemaps for your website, as well as any sitemap errors.
    Apr 2016
    Greece
    555
    Quote Originally Posted by MVM Infotech View Post
    Log into Google search console
    Go to the sitemaps section
    Click on the error to find out what is wrong.
    If the sitemap was deleted, or is corrupt, you will need to generate a new sitemap
    If the sitemap is inaccessible due to a permission setting, you need to change its permission setting. After that you can fix the sitemap problem, you need to re-submit the sitemap to google.
    Jul 2018
    United states
    163
    Can you please highlight the issue? Do you have a wordpress website?
    You can check your sitemap errors in the webmaster tools, which is offered by google and is totally free of cost. After knowing what are the errors in your sitemap try to remove those errors. If you are using wordpress then you can try free xml sitemap generator plugin, which creates sitemaps without any errors.
    Sep 2018
    Delhi
    110
    Simply ,You can generate new sitemap and fix the sitemap issues.
    Feb 2016
    Bangladesh
    486
    Test your sitemap
    Click Add/Test Sitemap on the report landing page.
    Enter the URL of the sitemap in the dialog that appears, and click Test.
    When the test is completed, click Open Test Results to check for errors. Fix your errors.
