Page 4 of 5 FirstFirst ... 2345 LastLast
Results 46 to 60 of 61
  1. #46
    Jun 2013
    11
    I had no idea about this, Thanks for sharing and give me knowledge about it.
  2. #47
    Registered User egihosting's Avatar
    Dec 2012
    45
    There is a great difference between colocation and dedcated server hosting.
    Colocation: You get rack space, power, bandwidth and other data centre facilities. Ship you server to the DC and they rack it for you. Here the server hardware belongs to the client. In most cases this service is unmanaged. You get support only for the facilities provided by the provider. Other services would be considered as Advanced Remote Hands.
    Dedicated Server: You can choose between managed and unmanaged services here. You get all the facilities like colocation and additional the server hardware is provided by the service provider. So if you face any hardware issues the provider will replace it for you. Mostly the software and applications are managed by the end customer, if they have not opted for fully managed services.
  3. #48
    Oct 2013
    11
    Colocation means to place your own server into a Data center and rent network and power.
  4. #49
    Oct 2013
    Colocation means service provided by Data center for owning there space, electiricity for monthly or yearly rental. This inculdes space and rack but no servers, which customer has to provide.
  5. #50
    May 2016
    32
    It is a department which aids with colocation. Below should explain what they do: Colocation (or co-location) is the act of placing multiple (sometimes related) entities within a single location. Colocation is often used in the data sourcing industry to mean off-site data storage, usually in a data center. This is very important for businesses since the loss of data can be crucial.
  6. #51
    May 2016
    28
    A colocation (colo) is a data center facility in which a business can rent space for servers and other computing hardware.
    Typically, a colo provides the building, cooling, power, bandwidth and physical security while the customer provides servers and storage. Space in the facility is often leased by the rack, cabinet, cage or room. Many colos have extended their offerings to include managed services that support their customers' business initiatives.
  7. #52
    Mar 2016
    7
    A colocation is a data center facility in which a business can rent space for servers and other computing hardware. There are many companies in India like BSNL Cloud, SIFY Data Cetner , Reliance Data Center end many more offering colocation services.
  8. #53
    May 2016
    12
    Quote Originally Posted by immediate View Post
    I never get this concept sorted out. As far as I'm knowledgeable, it's a unit rent in the data center?
    But how is it any different from dedicated hosting servers? Is colocation managed? Maybe just managed in the hardware level rather than the software level?
    In colocation the datacenters provide you secure and reliable location for your IT equipment. All services are provided within the datacenter like cooling infrastructure, power supply backup, network connectivity, remote hands on service, etc.
    Physical benefits: Usually the datacenter building has high security and all provide lockable cabinets or cages surrounding server rack.
    Cooling systems: colocation facilities provide powerful air conditioning systems to keep the air appropriately cool and moisture-free.
    Power back-ups: All colocation facilities have a power backup arrangement leading to no power failures. They also provide 99.99% uptime.
    Economic advantages: Colocation is the biggest advantage for small scale business as it saves a lot of infrastructure cost
  9. #54
    Apr 2014
    The benefits of a co-location are mostly physical.
  10. #55
    Jul 2016
    37
  11. #56
    149
    Colocation simply refers to moving or placing things together that provide rent out space in a data center and offers you power, bandwidth and cooling system in order to successfully run the server customers may also choose the colocation services because of high security that facilitates as a type of data center. The colocation center building is extremely secure and provides a vast array of back up strategies
  12. #57
    1,124
    A colocation is a data centre facility in which a business can rent space for servers and other computing hardware.
  13. #58
    Apr 2017
    New Delhi, India
    56
    Thanks for sharing the information about term I was Unaware about.
  14. #59
    Jun 2018
    ave, WA
    If you have a server and want to connect to the Internet, there are companies that will handle the link for you. This service is known as co location.The gap between a co host server along with a dedicated server is that in a dedicated environment the web hosting.
  15. #60
    A colocation is the data center facility in which a business can rent space for servers and other computing hardware from them.
