hi do any one help me in How to speed up Magento?
These are the key factors in speeding up Magento
1. Optimize
2. Enable catching
3. Enable GZIP compression.
Here are two points for your help,
1) PHP5 - Make sure the server you're hosted on supports php5. While the php5-cgi files Magento provides will work, they also drastically reduce the speed and increase the load on the server.
2) Enable Caching - Inside your Magento admin panel you'll find options for caching under System > Cache Management. Use these settings. You'll need to refresh the cache after future changes, but it will help speed loading for your visitors.
The new versions of Magento speed up much more than older version.
Many Magento issues are caused by slow performance. The recommended way to speed up Magento's performance is to enable its Compilation function. The performance increase is between 25%-50% on page loads.
You can enable Magento Compilation from your Magento admin panel > System > Tools > Compilation.
You should install Fooman Speedster.
This one made a massive difference to page loads for the first site I am testing.
You should enable Gzip Compression in .htaccess.
Try to update it to the new version or reinstall it! And you should also guarantee the wire speed of your PC.
My name is Linda Chow, I am running a small online clothing store where you can find and shop sweet Lolita dress, Gothic Lolita dress and many other lolita accessories | My New Store: Cheap Latex Clothing
Some of the methods to speedup Magento:
1 Install Fooman Speedster
2 Enable Gzip Compression in .htaccess
3 Install APC or Xcache
4 “Make sure your Apache configuration has KeepAlives enabled.
5”Modify the configuration for your MySQL server to take better advantage of your server’s RAM.
6 “Use a memory-based filesystem for Magento’s var directory.
I am going to download this new version.
