It is safe, why you think it's not? any problem while transfering file?
Thanks
Thanks
it will pull out of the socket safely, without damaging the connector or the computer power socket, or pulling the computer off.
thanks for sharing.
It depends on the file which you are going to share.
Have a good antivirus software downloaded in your pc so that it would let you know if any problems during file sharing.
If you want to stay safe when downloading or sharing your favorite files online, the following tips wil help keep you from getting busted.
-Use Private BitTorrent tracker sites:
It's fairly obvious and that is of the inherent risk of using public BitTorrent tracker sites instead of private members only ones. The risk stems from the fact that almost anybody can connect to the swarm and take a peek at your IP address.
Asia Affordable Web Hosting Provider
The Anti virus application must be updated with both systems, The file sharing also secured.
Comm100 - Leading Live Chat Software Provider
It depends on your data if it's carrying virus it will be definitely harmful for other computer.If your data is safe so don't worry feel free to transfer.
have you installed a anti spyware program on your PC ? If not, then installed one. I suggest you to go for Advanced System Protector, which is an effective solution to find and remove malware infections present on your PC. It also provides protection shields against malware threats. so, with this, you can securely share or transfer you data on a network.
I think whenever we are going to have a file transfer from one computer to another its secure if you have the proper security for your file such as passwords and the protocols etc.
Threats and viruses can always come up due to the sharing process. Keep in mind that the presence of anti-virus software can easily resist the same.
My windows xp will not start at all keeping restarting at the safe mode, safe mode with network, etc. Will not start at all, had a power outage and then the computer started doing this, what do I do?
fake doctors note
By sharing your system with other computers or device there are chances for viruses and other threats to affect it. By installing an effective anti-virus software or firewall helps your computers to stay safe.
if you installed security measure that wont harm your computer,hen it will be safe while transferring the file.
i think get a total security antivirus ,it will help you.
It is totally based on the administrator and also based on anti virus. It anti virus work efficiently then surly it will be safe.
