Results 1 to 12 of 12
    Apr 2012
    what is band width data transfer and its applications ?
    I want what's the difference between them ?
    Apr 2012
    America / Europe / Ireland
    76
    Bandwidth mentions the quantity of data goes through a set of connections. Data transfer refers to amount of traffic generated and transported from one location to another
    MineCraft Server | VPS | MineCraft Hosting | Web Hosting With AXELARIS Hosting, Take advantage of offers and promotions, You will not be disappointed !
    May 2012
    25
    Bandwidth is the amount of data that can be transferred at one time.
    Data transfer is the actual amount of data transferred.
    Think of it this way. If bandwidth were a tunnel, the bigger the tunnel the more cars can pass through it. Data transfer would then be the number of cars allowed to go through the tunnel in a given time period, say a month.
    Apr 2012
    452
    It is the quantity of data that goes through a set of connections.
    Senior Member DanielChew's Avatar
    Dec 2011
    Malaysia
    341
    Bandwidth refers to the capacity of a communications line or channel to transmit or receive information. Bandwidth in this context is measured in bits, bytes, kilobytes, megabytes and gigabytes.
    Data transfer is the amount of data that is transferred between your site and your visitors browser.
    Specialised in Web Hosting, Dedicated Server, Domain Name since Year 2001. Trusted by over 50,000+ clients worldwide
    Award & Achievements | Notable Clients
    Web Hosting | Domain | Virtual Private Server | Dedicated Server
    Exabytes Singaporehttp://www.exabytes.sg/
    Exabytes USAhttp://exabytes.com/
    Contact: sales@exabytes.com / sales@exabytes.sg
    Oct 2011
    770
    In computer networks, bandwidth is often used as a synonym for data transfer rate - the amount of data that can be carried from one point to another in a given time period.
    In general, a link with a high bandwidth is one that may be able to carry enough information to sustain the succession of images in a video presentation.
    Asia Affordable Web Hosting Provider
    Mar 2013
    46
    band width data transfer is the amount of data transferred at one time without any disturbance
    Apr 2017
    Hamburg
    742
    In computing, bandwidth is the bit-rate of available or consumed information capacity expressed typically in metric multiples of bits per second. Variously, bandwidth may be characterized as network bandwidth,[1] data bandwidth,[2] or digital bandwidth.[3][4]
    This definition of bandwidth is in contrast to the field of signal processing, wireless communications, modem data transmission, digital communications, and electronics, in which bandwidth is used to refer to analog signal bandwidth measured in hertz, meaning the frequency range between lowest and highest attainable frequency while meeting a well-defined impairment level in signal power.
    1,192
    Bandwidth is also described as the carrying capacity of a channel or the data transfer speed of that channel. Bandwidth exists in physical or wireless communication networks.
    Nov 2016
    134
    Bandwidth helps to describe the amount of data tranfer in Hertz and its application is Signal processing
    44
    Data transfer refers to the total amount of bytes of data server transfers to a site in a given amount of time. Whereas bandwidth refers to the maximum amount of data that is transferable in a given period of time.
    Feb 2014
    delhi
    572
    Bandwidth is the amount of data that can be transferred at one time where as Data transfer is the actual amount of data transferred.
