Results 1 to 5 of 5
    NS-Icon
    Guest
    Exchange Problem
    Was wondering if anyone could shed some light on this issue, we had exchange setup and it was running fine, but problem is I do not want to use IIS to host our websites, I prefer Apache, so I setup Apache on the default port 80 and modified IIS to operate on port 81. This is in Small Business Server, but the problem now is that when I visit http://localhost:81/exchange it does not load exchange but a page not found, I checked under IIS and all the sites are running as should be, what have I missed?
    Would really appreciate some feedback,
    Regards,
    Tahir Ahmed
    Feb 2007
    18
    Hi Tahir,
    I checked with one of our system admins. Short version is that you may want to seperate the services into different boxes (Apache on one box and Exchange & OWA on a second box ). This is what he said:
    You really shouldn’t be running two HTTP servers (different products) on the same system. By default ESM is dependent on IIS and I'm not quite sure what happens when you introduce a new web service.
    I would HIGHLY recommend not doing this.
    Why do you need both Apache and IIS on the same server?
    Move OWA to connect only via port 443 (SSL) and you have a much more secure connection.
    Alon Cohen
    Online Marketing Manager
    123Together
    www.123together.com
    Oct 2006
    16
    Chances are that most of the scripts or background calls of Exchange will try to communicate over port 80 and not 81.
    Apr 2010
    I think it is a great problem...
    Is there any solution for it....
    Thanks....
    Guest Moderator ~ServerPoint~'s Avatar
    Nov 2007
    1,846
    Very old thread is closed now.
    ServerPoint.com - a true hosting company offering online presence solutions since 1998
    Web Hosting, colocation, dedicated servers, Virtual Private Server (VPS) hosting
    Wholly owned multi homed network, servers and facilities
