Page 3 of 6 FirstFirst 12345 ... LastLast
Results 31 to 45 of 87
  1. #31
    Jan 2014
    43
    404 error shows that page is unable to display by the server.
  2. #32
    Sep 2014
    Gurgaon
    87
    404 error is that page are not exist on your web page which page user want to visit.
  3. #33
    Jan 2015
    12
    404 Error is a frequently-seen status code that tells you that a requested page is "Not found." when Google bot attempts to visit a page that doesn't exist either you deleted or renamed it without redirecting the old URL to a new one.
  4. #34
    Feb 2015
    404 error means the page does not exit which your looking.
  5. #35
    Jan 2015
    735
    The HTTP 404 Not Found Error means that the webpage you were trying to reach could not be found on the server. It is a Client-side Error which means that either the page has been removed or moved and the URL was not changed accordingly, or that you typed in the URL incorrectly.
  6. #36
    Apr 2015
    404 Error means that the webpage you were trying to reach could not be found on the server.
  7. #37
    Nov 2014
    United Kingdom
    31
    The 404 Not Found error, often called Error 404 or an HTTP 404 error, means that the webpage you were trying to load was not found.
  8. #38
    Apr 2015
    Chennai
    9
    Quote Originally Posted by Universal View Post
    The 404 or Not Found error message is an HTTP status code that means that the page you were trying to reach on a website couldn't be found on their server.
    Technically, an Error 404 is a client-side error, implying that the error is your mistake, either because a user attempts to follow a broken or dead link or the page has been moved or removed from the website and you should have known.
    Another possibility is if a website has moved a page or resource but did so without redirecting the old URL to the new one. When that happens, you'll receive a 404 error instead of being automatically routed to the new page. Probably you need to reconfiguree .htaccess file.
    Also it can happen if you installed a script or template that requires more resources than yours hosting plan provides in this case contact with your hosting provider.
  9. #39
    Apr 2015
    Kent, United Kingdom
    404 error tell that the page you are looking for its not found.
  10. #40
    Registered User GreenLionNet's Avatar
    Apr 2015
  11. #41
    Feb 2015
    49
  12. #42
    Mar 2015
    Pennsylvania, USA
    29
    I don't know what is 404 error .
  13. #43
    Jun 2015
    11
    404 error means that page request you put is not found on the server. 404 is a client side error it means that the page has been removed or an URL is not changed accordingly.
  14. #44
    May 2015
    11
    The 404 or Not Found error message is an HTTP standard response code indicating that the client was able to communicate with a given server, but the server could not find what was requested.
    ____________________
    Salesforce CRM services
  15. #45
    Jan 2015
    Uk
    31
    404 error page means which site you are searching is not available or not found server either you typed URL incorrectly....
