Page 4 of 7 FirstFirst ... 23456 ... LastLast
Results 46 to 60 of 99
  1. #46
    Mar 2016
    Forum posting is the best SEO Off-Page activities which allow us to create thread and post comment. It is the good source of getting backlink and traffic.
  2. #47
    Jul 2016
    New Delhi
    60
    If you post in a relevant niche forum then the answer is YES. It helps but I wouldn't main focus on forum backlinks as they are usually weak. You need link diversity, web 2.0 , authority , blog posting , social etc.
  3. #48
    Registered User simasingh's Avatar
    Aug 2016
    26
    Getting backlinks through forums can be considered to be a top notch method for link building. But the sad thing is that, not many SEO guys are making use of it. The obvious reason being, it is a difficult technique to follow. Check out some tips given below, for building links on forum.
    Discover forums in connection with your domain:
    You can do this by utilizing keywords alongside Google operators. For instance, in the event that you have to find a forum in a ‘dating category’, then hunt in Google as ‘Dating inurl:forum’. What will happen is; this search will scan for dating related websites that consists of “forum” in the URL and it will take you straightforwardly to the forum page of the specific URL you select from the Google.
    Extract websites that would create forum links after clicking on it:
    Note that you may likewise discover different websites in the middle of that would guide you toward other genuine forum meetings. Ignore it.
    Go through the forum rules to start with:
    Presently go through the forum rules to begin with, for the most part every forum board has distinctive designs and diverse positions. Subsequently, scan all through the site. A portion of the spots where you can discover it is 1. Inside the primary forum threads as sticky posts, you’ll first PM that you will get from Forum Admins, at the base of the footer, and so forth.
    Go through the registration process:
    Register by clicking on the “Sign Up” or ‘Register’ button. It will be more often than not at upper right or at beneath the header or elsewhere. Keep in mind, discussions or forums have a single of the top backlink building hotspot for SEO experts and Forum boards deliberately keeps the “Register” button at better places to maintain a strategic distance from spam enrollments.
    Verify that registration is done:
    Go to your mail inbox to check and affirm the registration. You’ll receive the mail on the mail address that you have entered during enrollment. Please keep in mind that the mail will be deferred because of a few situations like server traffic, manual confirmation, and so forth.
    Wait for the admin:
    Indeed, even in the wake of confirming the mail, you might be put on hold till Admin physically changes your enrollment status to ‘live’. It might take from 5 minutes to inconclusive time contingent upon the administrator’s availability.
    Again go through the rules:
    This is absolutely necessary. Guess what? All the Forum sheets have the same IP Banned rundown, that is, if your IP address has been banned on one forum, you’ll be naturally banned on other forum boards as well. Subsequently, read the tenets well before making your first post.
    Post into the forum:
    In the wake of perusing the standards, you’ll know when and how to make your first post. To control the spamming action, forum boards has the hardest rules on the web and even it has two kinds of moderation human moderation and auto moderation. Henceforth, begin posting precisely simply in the wake of studying all the guidelines identified with the forum, identified with the link, identified with the thread category you are selecting to post, and so on.
    Build links:
    There exist two kinds of forum links; i.e., Post and Signature. Once you enter your links in the Signature field which you’ll more often than not find in the ‘user control panel’ menu at the top, it is called as signature links. When you post links physically inside the posts you write in threads, these are called as ‘Post links’. Both have favorable circumstances and drawbacks. Signature links is consistent thus will be same in all the posts it shows on and your task is less demanding to post links. Be that as it may, you may never have the capacity to be found in a forum board on the off chance that you have access to signatures. Thus, first verify ‘user cpanel’ and discover the “signature” tab. In the event that you don’t discover it, look for the threads using search box on forum board with the keyword ‘signature’. Presently read every one of the postings to know where and how to utilize signature in the event that it’s accessible. Additionally comprehend that a few signatures permit either html tags or bb codes or nothing. These fluctuate at each forum boards for the most part. The second link type is the post links any link that you include inside a post will be post link. The vast majority of the forum has formatting choices thus you can choose the keyword you need to post link on and select the “URL” alternative at top and enter the URL you need to link to, you can likewise have naked URLs inside the post, yet these again relies on the forum sites you are posting at.
  4. #49
    Apr 2015
    134
    Yes, Absolutely true and the discussion could make the gaining of knowledge and also SEO technical improvement in keyword strategies.
  5. #50
    Mar 2016
    132
    Yes, forum Posting Is Best Seo technique, because most of my Google back links is from Forums sites
  6. #51
    Aug 2016
    United Kingdom
    Yes, Forum posting is the best seo techniques.
  7. #52
    Aug 2016
    130
    Warriorforum is one that I have found useful. There is also SEOBook which has a premium forum that I recall is a few hundred dollars per month.
    Tool,video training, book...See more.
    Instaffiliate Review - Check it NOW.
  8. #53
    Aug 2016
    16
    Ya obviously Forum is most important part in SEO in improving ranking.
  9. #54
    Aug 2016
    15
    Each link building has their own status as per I think Forum posting is best for Link juice.
  10. #55
    Junior Member 60degree1's Avatar
    Sep 2016
    Mohali, Chandigarh
    23
    I think forum posting is best way to get targeted traffic in search engine optimization.But when you using forum posting make sure Forum should be related with your topic.
  11. #56
    Apr 2017
    Post
    Quote Originally Posted by hopy View Post
    Can i consider forum posting as the best SEO technique?
    The best seo websites are the ones with high domain authority that fast track the process of increasing rankings. Forums or Article Submissions are basically websites and the metric that makes them the best is domain authority, page authority and relevancy.
  12. #57
    Apr 2017
    38
    Best advice is to avoid such thin quality techniques. Focus on better ways to promote your products/services. Blog commenting and forum postings are old fashioned.
    Rather focus on participating in forums and relevant communities genuinely. Don't just spam by unnecessary including links in your responses or comments. Read the blogs which are some value and leave a genuine comment. You can definitely leave your link there but do add the purpose of leaving your link there or people will start reporting spam.
    And, there is not OR in online marketing, it always AND, do this and do that, try everything which can help you get good results and help you rank your website in SERPs.
  13. #58
    Apr 2017
    107
    Yes, Forum posting which is one of the preferable off-pafe SEO technique. Forum posting are type of Q&A which is categorized into different topics. So related topics should be used because you have add in this post as signature and that is the best way because all that sites is daily crawling.
  14. #59
    Nov 2016
    Kolkata
    378
    It is the best way to increase traffic.
  15. #60
    Apr 2017
    38
    Though, many SEOs today see forum posting as blackhat or spammy link building techniques. However, I personally think that if used properly this activity can offer a lot of value to you. You can
    Establish yourself as an expert in a niche by joining a niche-focused forum say warrioforum for digital marketing and web design/development.
    Get traffic/backlinks via your signature.
    Share links to your blogposts while answering a relevant forum question.
    Make connections with other influential members in your community via forum posting.
    Get to know about various offers that other members are offering such as any discount on a particular service which might help you or your client.
