Page 4 of 5 FirstFirst ... 2345 LastLast
Results 46 to 60 of 63
Thread: What is WHM ?
  1. #46
    Apr 2014
    With its first-class support and rich feature set, cPanel & WHM has been the web hosting industry's most reliable, intuitive control panel since 1997.
  2. #47
    618
    WHM is the administrative panel of cPanel ( which is hosting control panel ). This is the easiest way to manage your reseller hosting. You can purchase a reseller hosting with WHM from the following hosting provider.
  3. #48
    Feb 2017
    756
    WHM stands for Web Host Manager that gives you the administrative access to the back end of cPanel so that we manage our website and other processes.
  4. #49
    Mar 2017
    37
    cPanel WHM = WebHostManager
    WHMCS = WebHostManagerCompleteSolutions
  5. #50
    WHM stands for Web Host Manager which is a powerful program.
  6. #51
    Feb 2017
    130
    WHM is a Web Host Manager and cPanel's masters management tool. It provides more control and flexibility to manage the hosting accounts and achieve web hosting success.
  7. #52
    Oct 2015
    92
    Web Host Manager, or WHM, is a powerful program that allows administrative access to the back end of cPanel.
  8. #53
    Aug 2017
    brasil
    33
    Web Host Manager, or WHM, is a powerful program that allows administrative access to the back end of cPanel. There are two versions that Host Gator uses. Reseller accounts get basic WHM.
  9. #54
    Dec 2015
    56
    hi,
    WHM is a management tool for hosting reseller.... with cpanel , whmcs and cpanel this is best combination for shared hosting,,,,
    "Powerfull state of the art DELL servers!"
    VpsWebServer - Ultimate Windows VPS hosting | Dedicated hardware MS Hyper-V technology Premium bandwidth providers
    SupportTM - Chat support Full 24/7 help desk support Email support
  10. #55
    May 2016
    india
    52
    Hi Friends, WHM means Web Host Manager is the account management panel that allows the hosting provider to their customers' accounts.
  11. #56
    Registered User Ms Monthana's Avatar
    The Web Host Manager (WHM) is the account management panel that allows the hosting provider to manager their customers' accounts.
  12. #57
    Registered User 24x7servermanag's Avatar
    Jul 2017
    1,022
    WHM provides the interface used for administrative control. It is used with cPanel. WHM work as backend. It has various features which are used for managing the functionalities handled using command line access. It comes with reseller service, VPS and dedicated server. Here are the functionalities handled by WHM -
    1. Create/delete/update the account
    2. Manage the bandwidth, resourcres
    3. Handling the DNS Zon
    4. Creating the nameservers and assigning them to correct IPs
    5. Firewall setup
    6. Various Email Functionalities
    Server Management Company
    India's Leading Managed Service Provider | Skype: techs24x7
    Cpanel Technical Discussions - Lets talk !
  13. #58
    1,124
    WHM stands for Web Host Manager. It is a server management interface from cPanel. It is a web application that is easy to use and allows administrative control of the dedicated or virtual private server. WHM offers two levels of server administration. First is Reseller Rights and Full server management Rights.
  14. #59
    Apr 2018
    30
    WHM gives you a suite of tools to easily do the following things:
    Create, delete, and suspend your cPanel accounts.
    Manage and monitor your sites (password resets).
    Access to check and change all of your domains' DNS zones.
    The ability to configure your own customers' support requests through cPanel.
    Permission to check the server information and status.
    Ability to create your own default page when you create a new account.
    Access to customize your hosting and control panel with extensive branding.
    Ability to change your client domain names and usernames.
    Hop between every cPanel on your account and access/change anything that does not require SQL access.
    Hope this will help you to understand about WHM
  15. #60
    May 2018
    159
    As the name suggests, WHM helps manage web hosting at an host level.
