Page 2 of 2 FirstFirst 12
Results 16 to 25 of 25
Thread: What is XML?
  1. #16
    Dec 2016
    24
    Extensible Markup Language (XML) is a markup language that defines a set of rules for encoding documents in a format that is both human-readable and machine-readable. The W3C's XML 1.0 Specification and several other related specifications—all of them free open standards—define XML
    The design goals of XML emphasize simplicity, generality, and usability across the Internet. It is a textual data format with strong support via Unicode for different human languages. Although the design of XML focuses on documents, the language is widely used for the representation of arbitrary data structures[6] such as those used in web services.
  2. #17
    Mar 2016
    Essex
    26
    Hello Friends,
    XML is a file extension for an Extensible Markup Language (XML) file format used to create common information formats and share both the format and the data on the World Wide Web, intranets, and elsewhere using standard ASCII text.
  3. #18
    Dec 2016
    154
    a metalanguage which allows users to define their own customized markup languages, especially in order to display documents on the Internet.
  4. #19
    Feb 2017
    219
    XLM is standing for Extensible Markup Language.
  5. #20
    Registered User 24x7servermanag's Avatar
    Jul 2017
    1,022
    XML is the extensible markup language. It s used to store and transport the data. It is self descriptive language. It just has the information wrapped in the tag. The data is stored in simple text format in the XML. This provides a software- and hardware-independent way of storing, transporting, and sharing data.
    The main use of XML is the interchange of data over the Internet.
    Server Management Company
    India's Leading Managed Service Provider | Skype: techs24x7
    Cpanel Technical Discussions - Lets talk !
  6. #21
    ghaziabad
    280
    XML is the extensible markup language, is a markup language that defines a set of rules for encoding documents in a format that is both human-readable and machine-readable.XML tags are not predefined in XML. You must define your own tags
  7. #22
    184
    XML is a development language. This terminology is used to make website sitemap which will help to webpages your websites quicker in google.
  8. #23
    Oct 2017
    32
    I agree with pellekarlsson which posted above about XML. XML is short for "Extensible Markup Language (XML) is a markup language that defines a set of rules for encoding documents in a format that is both human-readable and machine-readable. XML is much like HTML, but XML was designed to describe data and HTML was designed to display data. Also XML is not a replacement of HTML." In layman's terms this explanation is exactly what XML encompasses.
  9. #24
    866
    XML remains for Extensible Markup Language. It is a content based markup dialect got from Standard Generalized Markup Language (SGML).
  10. #25
    XML stands for eXtensible Markup Language, also known as the extended markup language proposed by the W3C for the purpose of creating other markup languages
