Page 3 of 5 FirstFirst 12345 LastLast
Results 31 to 45 of 62
Thread: What is FTP?
  1. #31
    Jul 2016
    113
    FTP stands for "file transfer protocol." FTP powers one of the fundamental Internet functions and is the prescribed method for the transfer of files between computers. It is also the easiest and most secure way to exchange files over the Internet.
  2. #32
    Jul 2016
    113
    An FTP server is a software.html application running the File Transfer Protocol (FTP), which is the protocol for exchanging files over the Internet.
  3. #33
    Jul 2016
    113
    File Transfer Protocol (FTP) is a standard Internet protocol for transmitting files between computers on the Internet over TCP/IP connections.
    FTP is a client-server protocol that relies on two communications channels between client and server: a command channel for controlling the conversation and a data channel for transmitting file content. Clients initiate conversations with servers by requesting to download a file. Using FTP, a client can upload, download, delete, rename, move and copy files on a server. A user typically needs to log on to the FTP server, although some servers make some or all of their content available without login, also known as anonymous FTP.
  4. #34
    Member marisalewis24's Avatar
    Jul 2016
    96
    The File Transfer Protocol (FTP) is a standard network protocol used to transfer computer files between a client and server on a computer network. FTP is built on a client-server model architecture and uses separate control and data connections between the client and the server.
  5. #35
    Jul 2016
    81
    FTP works in the same way as HTTP for transferring Web pages from a server to a user's browser and SMTP for transferring electronic mail across the Internet in that, like these technologies.
    FTP uses a client-server architecture. Users provide authentication using a sign-in protocol, usually a username and password, however some FTP servers may be configured to accept anonymous FTP logins where you don't need to identify yourself before accessing files. Most often, FTP is secured with SSL/TLS.
  6. #36
    Mar 2016
    118
    "FTP" stands for File Transfer Protocol and it is method by which files can be transferred from one host computer to another; over a TCP-based network like the Internet.
  7. #37
    274
  8. #38
    Oct 2016
  9. #39
    Registered User sanusense's Avatar
    Oct 2012
    61
    File Transfer Protocol (FTP) is the commonly used protocol for exchanging files over the Internet. FTP uses the Internet's TCP/IP protocols to enable data transfer.
  10. #40
    Can anyone tell me what exactly is this used for?
  11. #41
    618
    FTP is built on a client-server model architecture and uses separate control and data connections between the client and the server. FTP users may authenticate themselves with a clear-text sign-in protocol, normally in the form of a username and password, but can connect anonymously if the server is configured to allow it. For secure transmission that protects the username and password, and encrypts the content, FTP is often secured with SSL/TLS (FTPS). SSH File Transfer Protocol (SFTP) is sometimes also used instead, but is technologically different.
    The first FTP client applications were command-line programs developed before operating systems had graphical user interfaces, and are still shipped with most Windows, Unix, and Linux operating systems.Many FTP clients and automation utilities have since been developed for desktops, servers, mobile devices, and hardware, and FTP has been incorporated into productivity applications, such as web page editors.
  12. #42
    Feb 2017
    755
    FTP refers to File Transfer Protocol which is used to exchange files or documents on the internet. IP protocol is used for transferring files through FTP
  13. #43
    Dec 2016
    36
    The File Exchange Method (FTP) is a standard system protocol used to transfer pc files between a customer and server on your personal pc system. FTP is built on a client-server model architecture and uses separate control and data connections between the consumer and the server.
  14. #44
    Apr 2014
    You can still use FTP with modern applications because it's common, supported and light-weight
  15. #45
    184
    FTP is short for Data file Exchange Method. It has own pros and cons. The main issue with FTP is that it has no comfort, the whole deal occurs without any comfort . That's why anyone able to record your deal.
