After being in Developement just over a year now we are now launching Billic to the public.
What is Billic?
Billic is a billing system with the potential to power your entire infrastructure. It is a complete modular solution which means you can remove the default modules, that you don't need or add your own. We have a lot of modules available free of charge from the Marketplace. The most important objectives for Billic are Security, Ease of Use and Flexibility.
Flexible
All pages and functions are coded as modules. You can add your own or remove default modules. You make your own website, we don't force you to use any of our pre-coded modules which come by default with Billic.
Easy to Use
Our system has been designed from the ground up to be easy to use. There's a client area and an admin area, yet the menus are in the same interface. When you're logged in as an admin you're presented an admin menu as well as being a normal user account.
Advanced Module System
The module system at the core of Billic is very powerful. It allows you to add pages, tools and systems to your website which together make your website customized in a one-of-a-kind, unique way.
Fast Installation
You can deploy Billic by uploading a very small PHP file which will download Billic for you. Then using our installer you'll be up and running in a few minutes.
High Capacity
Efficiently coded to support large databases of clients. Our system is still very responsive even when you have a million clients.
To see our features & Modules visit: https://www.billic.com/Features
We have 4 License Options:
Lite License
Up to 50 active Users or Services
Up-to 10 Order Forms or Plans
Limited to 1 website
Access to Free Modules
Access to Free Themes
Forum support only
Updates Included
Support Monitor
€5 per month
https://www.billic.com/Pricing
Standard License
Unlimited Users & Services
Unlimited Order Forms & Plans
Personal support included
Updates Included
Support Monitor
€10 per month
Unbranded footer for €2 extra
Owned License
Premium support for 2 years
Updates Included for 2 years
Support Monitor
€200 once off
Unbranded footer for €40 extra
Developer License
Unlimited websites
Premium support for 5 years
Updates Included for 5 years
Support Monitor
€2500 once off
Unbranded footer included
If you have any questions, feel free to contact us through our ticket system.
Regards,
Adam
