PHP is more SEO-friendly platform and also the .net can be used for the creation of websites with the SEO support.
as an SEO, I reccomend you to use wordpress, there is a plugin that you can use to hel an SEO Job. Also you have to use PHP script and use .net as your domain extension.
Hamura Agency : digital agency jakarta and digital marketing creative in Indonesia.
For best website platform for SEO, I recommend to create your website in
HTML or WordPress
If you are going to create your website in WordPress so it is best because there are lots of plugins available related to SEO. By using them you can insert title, description and also helps to reduce page speed.
WordPress also provide user friendly URL so user can understand easily and also helps in ranking as well.
Well, there are lots of platform for SEO. However, if you want a free platform, both Prestashop and Wordpress are good choice. You can refer to this site and then make your decision litextension.com
Regards
wordpress is number one choose for every people, you know this 2.0 platform? it is very easy for beginer to use
WordPress is a best platform for SEO. There are many plugins are available that help to boost your seo and easy to use.
html & php best platform for seo.
Wordpress & PHP best website platform for seo.
Wordpress is best.
I actually set up my blog with the help of YouTube tutorials, so you don't have to be exceptionally tech savvy to set it up.
I would recommend you WordPress as it is easy to learn and having a good interface.
You can read these blogs for more clarity.
https://www.searchenginejournal.com/...rm-seo/133643/
http://www.123articleonline.com/arti...e-your-website
If you are beginner then Wordpress is best platform for you.
I think WordPress is the best website platform for SEO.
wordpress is best compare to other
Compared to the .Net, pHp Wordpress which is really more friendly to the SEO and its betterment of the keyword occurrence through the search engine.
