Results 1 to 11 of 11
    Apr 2014
    167
    Difference in hosting
    What is difference between normal web hosting and cloud web hosting ?
    Aug 2015
    Pakistan
    128
    There are different types of web hosting like shared hosting, dedicated hosting, VPS and cloud hosting. There are many other but these are basic types. Cloud hosting has number of servers and in cases of one server crashes, other servers kick-in to provide needed resources. This is really helpful in traffic spikes and it also means redundancy of resources all the time.
    May 2008
    1,429
    Globalize your workforce on the cheap. People worldwide can access the cloud, provided they have an Internet connection.
    Streamline processes. Get more work done in less time with less people. I can recommend Stratus4.com and their cloud hosting deals.
    It has nice reliability, easy to use control panel and excellent customer support. Discount Code: S415OFF
    Jun 2013
    Forum
    5,019
    Cloud refers to an effective network of virtual hosting features and facilities which are hosted as well as managed by a third party. The companies have huge centers for data management. If you ever need hosting of data, you will have to buy or rent hosting service from them.
    Cheap VPS | $1 VPS Hosting
    Windows VPS Hosting | Windows with Remote Desktop
    Cheap Dedicated Server | Free IPMI Setup
    web hosting gives you a settled server or a segment of a solitary server, where cloud computing gives you the advantage of numerous servers all cooperating as one. Your specific site or application might just need one little divide of a solitary server, so there's no compelling reason to get a committed server. Those servers sit on, devouring power and space regardless of the possibility that it isn't needed. Where cloud computing truly offers advantages is the point at which a site or application gets hit with a considerable measure of activity in a short measure of time.
    Jul 2015
    84
    Both has its own benefits,
    Web hosting is allowing the client to use the server space as per his needs, server space is divided into many hosting packages, Where Client need to pay for complete package monthly, which is quite expensive.
    cloud Hosting is, allowing client to use the cloud Space to store the data, here client need to pay only for those resources which he use. Allows client to host his website to host on VPS by providing only necessary resources.
    Jul 2014
    227
    The main difference between cloud hosting and normal web hosting is that cloud hosting is clusters of servers where as normal web hosting are based on set up of single server so uptime differs and uptime will be almost 100% in cloud hosting.
    Aug 2015
    29
    Shared (Virtual) Hosting, Dedicated Hosting, Cloud hosting and many more.
    Jul 2015
    Brooklyn, USA
    333
    Web hosting is the business of providing server space, web services and file maintenance for websites controlled by companies or individuals that do not have their own web servers.
    Cloud computing is a type of computing that relies on sharing computing resources instead of having local servers or personal devices to handle applications.
    Faridabad
    There are different types of hosting like shared,reseller & cloud is in one of them. For more knowledge i can suggest u to visit onlinetroubleshooters.com
    thank you
    780
    WEB HOSTING -
    web hosting is necessary for any website it is the physical location of your website on the internet, an online
    web hosting is simply the process of offer location and maintenance for files and server space used to support
    web projects
    It includes the services where hosting include the services where individual users can build and store a small hosting services provider
    where it includes internet service providers to host their sites.
    CLOUD HOSTING -
    Cloud hosting provides a suite for virtual services.
    Cloud hosting makes applications and websites application and websites accessible using cloud resources
    unlike traditional hosting solutions are not depended upon a single server.
    Cloud Servers hosts an application or website ensuring greater flexibility and scalability.
    -Resources scale to user needs
    https://www.esds.co.in/enlight-cloud-hosting
    -Only pay for the resources used
    -Cloud hosting can support My SQL.
