Page 1 of 2 12 LastLast
Results 1 to 15 of 23
    Apr 2016
    4
    Full managed VPS questions
    Hi everybody!
    We are going to start a new project (e-store), but there is a little trouble. We sold an idea that we need to use a CMS system to our boss. It started great but then we ve lost a lot of speed and conversion. Lags, lot of lags, we ve called a support and they said that we need a VPS, cause CMS (1C-Bitrix) is very hugry for resources. Therefore, we need a good VPS with full support, cause im preety bad in technical questions and I am responsible for this. Waiting for your advices.
    1.What congiguration do i need? In perspective
    2.What range price i have to aim?
    3.It there protected from DDos аttacks?
    Thanks!
    Oct 2015
    79
    We can't advise you on the ressources question, it is probably why you were led on a VPS plan because on some you can modify ressources.
    Plus you should look for a provider who can offer you fully managed VPS.
    Thomas | Community manager | ikoula Dedicated servers, VPS and Public Cloud.
    Contact us | Follow us Twitter | Like us Facebook
    Apr 2016
    Well,we will need more details like what is your site cpu/ram usage.There are many vpses out there like ovh,ramnode which will suit your need is unamanged.For managed vps,I will recommend wiredtree or knownhost.
    Hostdare Unlimited cPanel SSD hosting | Managed cPanel Dedicated Servers | Dedicated server starting @17 usd/mo
    █ Cpanel/WHM | Not Oversold | Reseller / Managed dedicated Plans Available
    www.hostdare.com Email : sales@hostdare.com
    Apr 2008
    535
    While you run a eCommerce website, you are storing the most critical data such CC details of customers, personnel details of customer, billing addresses etc. You never know what website's going to be compromised and that might affect your website as well. So, hosting web shops in shared host is the major security risk. An eCommerce websites must be hosted under the isolated and more secure environment like either VPS Hosting or dedicated server. The web shops are never recommended to be hosted under shared environment because you will be sharing the server resources with 100s of other websites. Now coming back to your questions.
    1.What configuration do i need? In perspective
    >>It depends on the daily traffic you are receiving. However, you can start with 2 to 4 GB VM as a start-up and then upgrade later according to your requirement.
    >>You should consider the price range between 30 USD to 60 USD for 2-4 GB RAM VM.
    >>Yes, mostly HyperVisors are protected against the DDoS attacks.
    If you want to avail the most reliable VPS hosting services then I can suggest you AccuWebHosting as the most excellent web hosting provider with fastest and skilled support.
    AccuWebHosting.Com | ASP.Net Hosting Provider Since 2003
    Cloud Powered Hosting | Windows VPS | Dedicated Servers
    US Based Hosting Company | Trusted by 20,000+ Clients Worldwide
    Jun 2013
    Forum
    5,019
    A fully managed VPS hosting service will definitely help you to manage your hosting by web host technicians on your behalf. They will be responsible to install software and provide technical support for variety of needs.
    Cheap VPS | $1 VPS Hosting
    Windows VPS Hosting | Windows with Remote Desktop
    Cheap Dedicated Server | Free IPMI Setup
    Nov 2011
    263
    Are you looking for the provider as per your geo location or it does not matters much?
    Nov 2010
    946
    I think you need to get more options to choose from. My recommendation is to use Kvchosting.com VPS hosting deals. Their servers are provided by professional fast staff with high performance and featured cheap plans.
    Hey! It's That Guy!
    Senior Member transilvania's Avatar
    Dec 2006
    942
    The best VPS providers are yougottohaveithosting.co.za and a2hosting.com.
    Their support is very responsive and provides very good notices in advance of maintenance periods, etc..
    Servers are well-supported and prices are competitive.
    Apr 2016
    Quote Originally Posted by Invader View Post
    Hi everybody!
    Thanks!
    Hey
    You'll need at least 2 Gb RAM and 2 core CPU from my experience, and you'll need a room for future, so I can suggest you look for hoster where you can change a plan for existing VPS.
    Or you can look for possibility of purchasing a dedicated server alone, can't say for sure, didn't aware of your budget at all.
    And no, you can use CloudFlare for DDoS defense, and it's not included, at least I didn't heard of it.
    Mar 2016
    73
    solution
    Hi everybody!
    Thanks!
    For better solution provide me following information
    1) How many domains/websites you want to host.
    2) Disk space used by your websites.
    3) Average traffic received by your website in last three months and bandwidth usage.
    4) How many database you are using and disk space usage by database.
    ktchost.com - Reliable Hosting Provider
    E-commerce Ready Hosting | Pure SSD Cloud/VPS | Offshore Dedicated Server
    24/7 Reliable Tech Support | Monitoring Service | R1Soft Backup
    Oct 2010
    897
    Taking into consideration the situation you have fetched up I can say that Kvchosting.com will be really good for you. The pricing is low and uptime is high.
    Apr 2016
    4
    Thank you for all of your replies, guys
    I already find a solution
    I think I will use a first proposition
    Mar 2016
    91
    I think cloud sever hosting is option to good for you, for cloud server I will suggest you to go with eUK host's eNlight cloud as it comes with unique features of auto-scalability and pay per consume. eNlight Cloud analyses the resource utilization of VMs and automatically detects & adapts to it ensuring the seamless functioning. Auto scalability scales the resources such as RAM, Storage , Bandwidth etc. automatically as per the requirement of the users for e.g. If there is sudden spike in the traffic eNlight automatically up scales the resources similarly, it scales them down when not required. pay per consume feature enables user to pay only for the resources they have utilized. Which helps the customers to avoid any CAPEX OVERHEADS?
    Oct 2006
    876
    Fully-managed VPS deals are available from hostsailor.com and a2hosting.com.
    All the components are perfectly matched, they harmonize with each other without any performance losses. These are ideal conditions for reliable server operations , optimal security and the highest availability.
    Sep 2006
    853
    VPS deals from eWallHost.com are worth your attention.
    They are DDoS protected and they start low as 4.25$! Support is online for 24 hours.
