Thread: Need help
    Apr 2017
    Need help
    Hi everyone!
    I have a very bad wifi signal at home. In some rooms the signal disappears at all, is there a possibility to fix it?
    Mar 2017
    Delhi
    178
    Yes, contact your ISP for this problem but check the router range first.
    Oct 2015
    65
    Wifi technology is supposed to be used in onpen spaces only there is probably some materials in your home blocking the signal.
    To be able to use wifi anywhere in your house you have to buy a wifi extender to boost signal.
    Thomas | Community manager | ikoula Dedicated servers, VPS and Public Cloud.
    Contact us | Follow us Twitter | Like us Facebook
    Apr 2017
    Thanks
    Mar 2017
    33
    Of course. For example you can do some home DIY or buy a signal booster. I'd like to recommend the second option then you will definitely be satisfied with the result. By the way, it's absolutely safe and healthy for human.
    Apr 2017
    48
    You might want to check out your location. Is there any object that block the signal to you?
    Future products review - Review of hottest products before they are even launched. Take a look to become the first mover and enjoy that advantage.
    https://www.futureproductsreview.com/
    Registered User David910's Avatar
    Apr 2017
    93
    You should contact the customer support department of the network to check and fix for you.
    Your wifi supplier is the cause of problem, call them
    Aug 2016
    20
    Try wifi booster aur wifi repeater range extender it will solve your signal problem.
    Tours to Bhutan@Bokars | Tour Operator
