Page 1 of 2 12 LastLast
Results 1 to 15 of 22
Thread: Search Engines
    Search Engines
    The Internet is a wonderful place full of resources that can be really helpful for us.
    The best way for finding information is through a virtual search engine. A search engine explores the resources on the Internet and gives results. Search engines allow keyword searches and use crawlers to locate sites or pages the match requests.
    However, finding the information that is relevant for you is a challenge. Everyday more sites come into existence.
    A simple query like “web hosting” on Google returns 15,100,000 results. Now how does the user know which site is useful for him, thus creating an “Information Overload” of sorts. How does the user assure the quality of the information?
    The thing about search engines is that they generally display all the web pages that contain any or both the words contained in the search query.
    So comes the question of how to find the information you are looking for?
    There are various techniques that you can use to make your search query better which will help in getting you better and more relevant results.
    For instance if you use the “+” operator and restructure your query to “web hosting” + windows it will show only those sites that offer windows hosting. You can also use the “AND” Boolean operator, depending on what you are comfortable with.
    You can use the “-“ operator to make sure and key in “web hosting” – Linux thereby telling Google to make sure that it does not display Linux related hosts. This is the same as using the “NOT” Boolean operator.
    There are also keywords like ADJ, NEAR etc. that are used by some of the search engines. The NEAR operator looks for keywords specified in the query within certain proximity of each other i.e. it makes sure that both the keywords “web” & “hosting” are present on the same page and are placed nearby to each other in the text.
    The ADJ operator is a stricter filter and returns only those pages where the keywords are next to each other i.e. it will only return pages where the keywords “web” and “hosting“ are mentioned together.
    Another technique to make sure you get better results is to use a sensible query. Make use of words that you think will be contained on the site you are looking for “web hosting” is better then “I want web hosting”.
    Also remember that search engines normally ignore certain words like “a’, “for”, “of”, “in”, “at” etc.
    Another important thing to remember is that most search engines have a tips page that specifically contains information on how to make better searches on the search engine. It is always good to read these tips.
    Most search engines have an advanced search option that is really useful if you are not proficient at using operators while searching.
    Searching and finding what you are looking for is easy if you are armed with the know-how of how to do it.
    Cheers,
    Ashish
    ASP WEB HOSTING
    May 2005
    23
    Ashish;
    Do you offer a Diploma or Degree for reading all of your post? If you do I believe I'm working on a advance Degree. Ha Ha Ha ! keep up the good work!
    DogoTek Hosting !
    The World's Greatest Hosting & Reseller Programs $$$
    _____________________________________________
    Learn to Earn from home - 24Hrs a day!
    Nov 2003
    18
    Very important time saving advise! There are some articles in SearchEngineWatch.com that may be helpful.
    See: http://www.searchenginewatch.com/facts/
    There are articles on Search Engine Math, Power Searching For Anyone, Search Assistance Features, Search Toolbars & Utilities, and Boolean Searching.
    Hope you all find what you are looking for!!
    DiscountASP.NET - http://www.DiscountASP.NET
    Experience the Power of ASP.NET for Less
    - ASP.NET 2.0 Beta 2 Hosting
    Apr 2008
    535
    Very useful information. You may also refer below article:
    http://www.goodwebpractices.com/seo/...searching.html
    Thanks!
    Sep 2009
    Nevada,Newyork ,US
    Nice post, have informative data.
    it will save the time for those who are beginners because experts know that how to save the time..
    Guest Moderator ~ServerPoint~'s Avatar
    Nov 2007
    1,846
    I see no reason to continue such long thread so that is closed
    ServerPoint.com - a true hosting company offering online presence solutions since 1998
    Web Hosting, colocation, dedicated servers, Virtual Private Server (VPS) hosting
    Wholly owned multi homed network, servers and facilities
    Sep 2009
    319
    Very nice.Thank you for sharing it here.
    HostEase Web Hosting - Professional Web Hosting
    SoftLayer Datacenter and 99.9% Uptime Guarantee
    24/7/365 Technical Support
    Support Center|Call us at (302)-353-4678.
    Nov 2009
    22
    It worked! I'm having a hard time finding web hosting for link partners this time it's fast. I'm not into software when doing this task.
    Nov 2009
    U.K
    19
    Hello
    You really doing great job. Thank for sharing this nice information.
    I appreciate your post. Great job....
    Thanks
    Have a nice time ahead.
    Dec 2009
    Nice post and thanks again for sharing this knowledge.
    Jan 2010
    33
    ASPnix.com
    Nov 2009
    22
    Nice work mate. This enhance quality results.
    Registered User brainpulse's Avatar
    Jan 2010
    Noida
    445
    Re:
    good practices about Google advance search.
    dose any one have some more tips about allin google tags,
    Mar 2010
    7
    when the name of search engine comes ,I remember Google..
    Google is my favorite.....
    Thanks
    Wedding Video
    May 2010
    Thanks for this nice post. It is very much informative post.
    Well done.
