Results 1 to 12 of 12
    What is keyword research ?
    Hello Friends,
    Please tell Me,
    248
    Keyword research Means Keyword research is a practice search engine optimization professionals use to find and research actual search terms that people enter into search engines. This is a keyword research.
    Oct 2015
    Bangalore
    305
    Keywords Research is the most important. If you want to create the good and related keywords you should use the google keywords planner tool.
    Apr 2014
    167
    Keywords research is process that is pre-requisite to onsite and offsite SEO ? For keyword research we use keywords research tool and the best one tool is Google keywords planner tool
    Apr 2016
    Keyword Research helps you to Boost your Organic search traffic and ensure you are targeting the right keywords with this actionable guide to Keyword research.when somebody does a search in google's that's called a search, it's otherwise also called a keyword.
    613
    Jun 2013
    Forum
    5,019
    Keyword research is the practice of searching for the right keywords for your domain. Best keywords can be selected using Google keyword planner. It is the best free tool for high quality keyword research. They help to provide various keyword suggestions for your domain, and selecting the right keywords will help to rank your website higher in search results.
    Cheap VPS | $1 VPS Hosting
    Windows VPS Hosting | Windows with Remote Desktop
    Cheap Dedicated Server | Free IPMI Setup
    Apr 2016
    458
    Keyword research is the practice of identifying which phrases are used on search engines when people are looking for information and usually includes finding both the search volume and relative competitiveness of the terms.
    Keyword research is a critical component for search engine optimization because when used correctly it provides a road map for both the design and execution of building websites and developing content.
    Feb 2015
    Bangalore
    536
    Keywords are like a compass for your SEO campaigns: they tell you where to go and whether or not you’re making progress.
    Aug 2016
    212
    Keyword research is a practice search engine optimization (SEO) professionals use to find and research actual search terms that people enter into search engines. Search engine optimization professionals research keywords, which they use to achieve better rankings in search engines. Once they find a niche keyword, they expanded on it to find similar keywords. The process is usually aided by keyword suggestion tools, like the Google Adwords Keyword Planner, which offer thesaurus and alternate keyword suggestions.
    Usually, the various search engines provide their own keyword suggestion tools, which also include the number of searches for each of those keywords. The keyword researcher uses this information to select the correct keyword, depending on the SEO goals of the website. Around 20-25% of searches are of very specific long tail keywords entered into Google every single day it’s easy to rank said keywords, so long as you have a good amount of content and backlinks to match. Keyword research is a valuable and high return activity in the search marketing field
    Oct 2016
    65
    Keyword research is one of the most important, valuable, and high return activities in the search marketing field. Ranking for the right keywords can make or break your website. By researching your market's keyword demand, you can not only learn which terms and phrases to target with SEO, but also learn more about your customers as a whole.
