Page 1 of 3 123 LastLast
Results 1 to 15 of 35
    May 2015
    UK
    260
    What are the Advantages of Unix Hosting ?
    Hello everyone,
    Jun 2013
    Forum
    5,019
    Unix is an open source platform that it provides more security to your hosting services. It keeps your online data safe from any hacking.
    Cheap VPS | $1 VPS Hosting
    Windows VPS Hosting | Windows with Remote Desktop
    Cheap Dedicated Server | Free IPMI Setup
    Jun 2016
    Mumbai
    872
    Unix is a free platform, which means that your hosting company will not have to purchase the operating system for your server.
    Aug 2016
    113
    The unix operating system is one of the computing most significant technologies providing the framework that the familier linux and Mac OS X operating system were developed on. Unix is designed to maximize performance through economical memory use.
    Sofia, Bulgaria
    128
    There are pros and cons for every OS but lets check only the positive points. Cheap=free, lets say more secure, very well optimized.There free control panes also.
    Oct 2015
    65
    Hi sanjalisharma89,
    Unix OS has many advantages such as:
    - Price: you will not have to purchase the operating system for your server.
    -Scalability: More applications work on a Unix platform and you will have more choices to develop your site in many different directions
    -Performance: Unix servers work very well and quickly. Less system resources are required, which means less bandwidth and RAM usage for your site, which can be very helpful.
    -Applications: More applications and other languages were developed in Unix, so you will be able to run more applications on your site than you would if you selected a Windows platform.
    Domainsatcost.com
    Everything you need to be present online.
    May 2016
    287
    - Cost Effective
    - Access is easy
    - More Secured
    - Open source
    - supports many application development languages.
    and more.
    Registered User aditiaggarwal's Avatar
    Nov 2016
    2
    Since Linux or Unix hosting packages are typically cheaper than windows based server, they are not normally the choice for many businesses. There are many advantages to using Unix based server, which will be detail below.
    1, Cost
    2, Scalability
    3, Performance
    4, Applications
    5, Telnet and SSH
    373
    Nov 2016
    145
    Unix hosting packages are typically cheaper than Windows based servers, they are normally the choice for many businesses.
    Jul 2016
    100
    Disadvantages of Unix Hosting
    While there are many strong advantages to purchasing a Unix platform hosting package, there are still some disadvantages that you will need to keep in mind before jumping to any conclusions. Let’s take a look at some of the most common problems facing Unix hosting.
    Difficulty
    If you are not familiar with using Linux/Unix language, you will need to learn a completely new programming language. For customers who are used to their Windows operating system on their computer, this can be a huge downside. Your slashes will be going in different directions, and the commands are completely different from Windows commands. For webmasters pressed for time, having to learn a completely new programming language can be too much.
    In addition, you will need to be familiar with file permissions and how that is done on a Unix server. Many scripts require you to set specific file permissions on folders and files included in the script. This is called CHMODING and can be very difficult to grasp at first. If your permissions are incorrect, your script will not run, making it very frustrating for new users.
    Telnet, which is typically used to administered processes in Unix can be a completely foreign application to someone who is not used to Unix. While it is not extremely difficult to master the basic concept of Telnet, you will need to learn a variety of commands that are necessary to use it. While many webmasters never need to use Telnet to administer their Unix platform site, if you plan to use advanced applications, it definitely comes in handy.
    Front Page Extensions
    If you are using Microsoft Front Page to develop your website, you will need to make sure that your Unix host offers Front Page extensions. If you don’t have these extensions, you will not be able to use Front Page to its complete abilities. Most Unix based hosts are now offering these extensions, but there are still several that do not.
    No .ASP
    If you plan to use Active Server Pages or .ASP for your website, you will not be able to use this language on a Unix server. Since this scripting language is gaining in popularity, this can be a tremendous downside if you select a Unix based host.
    No Visual Basic
    Like .ASP, Visual Basic is not supported on Unix based hosting, so again, if you plan to use this, or any Windows based applications, a Unix host will not be an alternative for you.
    Now that you are well versed in the ups and downs of Unix hosting, let’s put everything together into what you will need to consider before selecting a Unix based hosting package.
    With this toolkit, you can optimize on-page SEO on your website
    My Review
    Igloo App Building your page easier- SSee my Igloo ReviewReview
    Feed Back tool allows you to ethically spy Convertifire Review
    1, Cost
    2, Scalability
    3, Performance
    4, Applications
    5, Telnet and SSH
    Oct 2016
    302
    It is No Visual Basic
    There are many advantages to using UNIX based server. They are normally the choice for many business. here some advantages,
    1, Performance
    2, Security
    3, Complexity
    4, Assistance
