Hello Friends,
Please tell me what is responsive web design.
Hello Friends,
Responsive webdesign are those designs which will run on your desktop system, laptop, tablet and mobile etc. properly when they load. Responsive websites are displayed properly in any resolution. You should have proper CSS for working of the responsive site.
The name itself is self explanatory. Your website should be responsive on all the possible platforms. Be it mobile, Laptop, Desktop or Tablet.
The design and development should be responsive to screen size, platform and orientation. You need to make proper use of CSS.
If your site is not responsive then you might loose on valuable customers. So make sure you cross check your webpage/website and its implementation on all the platforms before making it live
Responsive web design (RWD) is an approach to web design aimed at crafting sites to provide an optimal viewing experience—easy reading and navigation with a minimum of resizing, panning, and scrolling—across a wide range of devices (from desktop computer monitors to mobile phones).
Responsive Web design is the approach that suggests that design and development should respond to the user’s behavior and environment based on screen size, platform and orientation.
Responsive Web Design is those web designs that are accessible from any device like mobile, Tablets, Desktop. Responsive Web Design improves the user Experience.
Responsive Web configuration is the approach that recommends that plan and advancement should react to the client's conduct and condition in view of screen size, stage and introduction. The training comprises of a blend of adaptable frameworks and formats, pictures and a savvy utilization of CSS media inquiries.
The purpose of responsive design is to have one site, but with different elements that respond differently when viewed on devices of different sizes.
responsive web design is if the website viewed from hanphone then the website will follow the size of hanphone or tablet.
Responsive website design is an important aspect of web development. You website has to be responsive on all the possible platforms used byt the end user. It means that if your website functions properly on desktop but doesn't work properly on mobile then your website is not responsive.
If your website functions properly on all the possible platforms like Desktop, Mobile, laptop, Tablet etc. only then it is called as responsive website. If the user zooms in then the screen size should adjust automatically.
It is highly recommended that you have a responsive website because it does help in improving user experience.
A responsive site enables you to have just one website that automatically adjusts to fit the screen size of the tablet, Smartphone, desktop, or other device that your audience is using to view your site Responsive Web design is the web platform that suggests that design and development should respond to the user’s behavior and environment based on screen size, platform and orientation. The practice consists of a mix of flexible grids and layouts, images and an intelligent use of CSS media queries. As the user switches from their laptop to iPad, the website should automatically switch to accommodate for resolution, image size and scripting abilities.
You can say responsive design means various device friendly website with new function.
Responsive web design is those designs which will run on your desktop system.
Responsive web design makes your web page look good on all devices.
Responsive web design uses only HTML and CSS.
Responsive web design is not a program or a JavaScript.
Responsive Webdesigns means your website is open properly and looks good at all type of devices for example:- laptop,mobile etc.,it response according to the user's behavior with size,resolution, plate form etc.
Responsive Websie Design or RWD as it is commonly referred to, implies the formatting of Website design in a way that it most optimal for viewing and navigation across a wide range of devices, including traditional PCs, smartphones and tablet devices.
Responsive Web design is the approach that suggests that design and development should respond to the user's behavior and environment based on screen size, platform and orientation.
Hi there,
Responsive web design means when a website is designed and developed according to the compatibility of the various internet supportive gadgets.
Responsive web design make sure that the web design itself is users' friendly in all types of gadgets used.
Hello Friends,
Responsive website means the visibility of a website is clear and neat in all type of devices like desktop, laptop, mobiles, taps etc....It improves the user friendly of the website.
Responsive web design is the approach that will make you suggest that the design and development should be respond according to the users behavior and environment which is based upon the screen size,orientation or platform.
It is about using HTML and CSS to resize, hide, shrink, or move the content to make it look good on any screen.
Responsive web design is an approach to web design which makes web pages render well on a variety of devices and window or screen sizes.
Responsive Web design also known as RWD is having a website that is responsive enough to adjust with the customer browser. Responsive Web Design means that a single site will automatically reformat itself to appear well on any device screen width. It will have the same URL for desktop, mobile and tablets.
Responsive Web Design (RWD) is a new trend in which the web design and development process will meet every device and user environment according to the dimensions and dimensions of the screen of the device.
RWD is the practice of building a webpage or website appropriate to work on every device (like the laptop, computer screen, and cell phone) and every screen size, no matter how large or small. Responsive web design(RWD) is not a program or a JavaScript. It makes your web page or website look good on all the devices. Overruling your rivals is genuinely a tough task when you are a beginner in the business. Here, you can take help of the proficient web development companies, who will help you a lot to take your business to new heights of success.
Responsive web design is an approach to web design which makes web pages render well on a variety of devices and window or screen sizes. Recent work also considers the viewer proximity as part of the viewing context as an extension for RWD.
Responsive design are the shorter view of desktop design..
Normally it will appear in different different devices such as mobile,tablet etc....
Responsive design is a front-end development process intended for moulding website design and user experience to the user’s device, whether desktop, tablet, or mobile.
Responsive design means the design will be compliant across all devices such as mobile, desktop and tablet.
Responsive Web Design convert the websites mobile friendly - easy to navigate from all devices. https://pauldechant.blogspot.com/
Responsive Web design challenges Web designers to adopt a new mindset to their design and coding processes. Responsive web design is an approach to web design in which a site is crafted to provide an optimal viewing experience—easy reading and navigation with a minimum of resizing, panning, and scrolling.
Responsive web design means ' your web-design will change it's proportions according to device's display size'. You may visit our blog https://adndigital.com.bd/7-tips-for...ur-web-design/.
Responsive design is a front-end development process intended for molding website design and user experience to the user’s device, whether desktop, tablet, or mobile.
In responsive, a cascading style sheet (CSS)—essentially what defines the format and layout of a web page, is leveraged to permit a website to scale to the width of a browser, independent of device type. Javascript and js libraries such as JQuery and Modernizr are also used to accompany this behavior for resizing more dynamic objects like masonry galleries as well as converting mouse activities to touch activities.
Unlike adaptive design or mobile detection, responsive design does not leverage device detection, so rather than querying the device with backend logic, CSS media queries are used to determine things like the width and orientation of the device screen—your browser.
Responsive Web Design is about using HTML and CSS to automatically resize, hide, shrink, or enlarge, a website, to make it look good on all devices (desktops, tablets, and phones)
When making responsive web pages, add the following <meta> element in all your web pages:
<meta name="viewport" content="width=device-width, initial-scale=1.0">
Because responsive web design is mobile-friendly, it helps increase visibility on search engines, which in turn can mean more visitors to your website. More traffic results in better lead generation, added conversions and increased sales—three big reasons why you need a responsive web design!
Responsive web design is mobile-friendly, helps increase visibility in search engines, which in turn can mean more visitors to your website. More traffic leads to better conversion leads and increased sales - three main reasons why you need responsive web design.
Responsive Web Design is about using HTML and CSS to automatically resize, hide, shrink, or enlarge, a website, to make it look good on all devices (desktops, tablets, and phones):
Responsive design is an approach to web page creation that makes use of flexible layouts, flexible images, and cascading style sheet media queries. The goal of responsive design is to build web pages that detect the visitor's screen size and orientation and change the layout accordingly.
Great post you are shared,
purpose of Responsive web design is making web pages that render perfectly on a different devices and screen sizes.
