Page 2 of 2 FirstFirst 12
Results 16 to 26 of 26
Thread: What is Schema?
  1. #16
    Sep 2020
    chennai
    102
    A schema is the structure behind data organization. It is a visual representation of how different table relationships enable the schema’s underlying mission business rules for which the database is created.
  2. #17
    Aug 2020
    355
    The term "schema" refers to the organization of data as a blueprint of how the database is constructed (divided into database tables in the case of relational databases). The formal definition of a database schema is a set of formulas (sentences) called integrity constraints imposed on a database.
  3. #18
    Aug 2020
    258
  4. #19
    Registered User simasingh's Avatar
    Aug 2016
    26
    Schema markup is a great way to help your website stand out from your SEO competitors. Here's why you need schema and how to add it to your webpages.
    Schema markup, found at Schema.org, is a form of microdata. Once added to a webpage, schema markup creates an enhanced description (commonly known as a rich snippet), which appears in search results.
    Via Schema.org:
    “Most webmasters are familiar with HTML tags on their pages. Usually, HTML tags tell the browser how to display the information included in the tag. For example, <h1>Avatar</h1> tells the browser to display the text string “Avatar” in a heading 1 format. However, the HTML tag doesn’t give any information about what that text string means—“Avatar” could refer to the hugely successful 3D movie, or it could refer to a type of profile picture—and this can make it more difficult for search engines to intelligently display relevant content to a user.”
  5. #20
    Aug 2018
    1,141
    Oryon Networks | Singapore Web Hosting | Best web hosting provider | Best web hosting in SG | Oryon SG | Singapore Hosting
  6. #21
    Aug 2020
    20
    Schema markup is code that helps search engines to understand your content and better represent it in the search results.
  7. #22
    Aug 2020
    355
    A schema is an outline, diagram, or model. In computing, schemas are often used to describe the structure of different types of data. Two common examples include database and XML schemas
  8. #23
    Sep 2020
    23
    Schema.org is a set of extensible schemas that enables webmasters to embed structured data on their web pages for use by search engines.
  9. #24
  10. #25
    Aug 2020
    355
  11. #26
    Aug 2020
    258
