Results 1 to 5 of 5
    May 2019
    44
    How can Web Analytics help generating leads?
    Nov 2018
    557
    Web analytics is one of the best ways to truly understand your website’s visitors, but many business owners ignore this valuable tool. In fact, one of the more common myths is that the higher the number of visitors to your website, the better your ROI.
    Feb 2019
    1,587
    If properly used, Google Analytics can provide you with a vast amount of data ... you use to bring traffic to your website to help you generate even more leads. 1. ... campaigns you currently use to send traffic to your lead generation Web page.
    Nov 2018
    69
    Google analytic is free of cost web tool, which is utilized to track information that explains user interaction on your site whenever you are planning a search engine optimization campaign Google analytics will help you to measure the performance to have an effective SEO campaign. This tool will provide comprehensive information about multiple aspects of how your website is generating traffic.
    May 2019
    226
    For us to get started, you’re going to need to have Google Analytics tracking set up on your website, and have the proper access to your account. For those that don’t have it set up, or don’t know if they have it set up: this isn’t that hard! I suggest you take the following steps (if you already have Google Analytics tracking enabled and you’re roaring to go, you can skip this part):
    1. Ask your IT, Web Development or Marketing Department if you have Google Analytics tracking enabled and if you can have access to it.
    2. If for some reason, you don’t want to talk to those departments, you can check for yourself using tools like BuiltWith or Google Tag Assistant and then ask around your organization for access.
    3. If you don’t have it set up, its super simple to do, I suggest you follow the instructions that Google has published!
