Results 1 to 10 of 10
    Aug 2017
    New Delhi
    88
    What is page speed and how does it matter?
    Feb 2019
    328
    Page speed in SEO refers to the speed in which a page is loaded. Better load times (closer to zero seconds) are preferred by search engines over load times that take many seconds. Faster pages are said to have an increased potential of ranking highly for search queries compared to slower pages.
    The reason Google rewards fast websites is that it wants its users to associate their search engine with findings answers to the queries as fast as possible. As long as Google can get everyone to be happy about the results they provide, the people will continue using Google, and they will be able to keep selling their ads.
    You can learn more about the page speed of your website and how to improve it via a broad range of tools, including:
    Website Performance and Optimization Test
    Website Speed and Performance Optimization
    Improve Traffic and Conversion Easily
    Jun 2018
    1,416
    How long it takes your website/webpage to load.
    Before you get started on trying to improve your speed you should take a look at what it is currently at. The page speed checker and the Google insights checker should be able to give you a good look.
    1. Minimize HTTP Requests
    According to Yahoo, 80% of a Web page’s load time is spent downloading the different pieces-parts of the page: images, stylesheets, scripts, Flash, etc. An HTTP request is made for each one of these elements, so the more on-page components, the longer it takes for the page to render.
    That being the case, the quickest way to improve site speed is to simplify your design.
    Streamline the number of elements on your page.
    Use CSS instead of images whenever possible.
    Combine multiple style sheets into one.
    Reduce scripts and put them at the bottom of the page.
    Always remember, when it comes to your website, leaner is better.
    Pro Tip: Start a campaign to reduce the number of components on each page. By doing this, you reduce the number of HTTP requests needed to make the page render—and you’ll significantly improve site performance.
    2. Reduce server response time
    Your target is a server response time of less than 200ms (milliseconds). And if you follow the tips in this article, you’re well on your way to achieving this.
    Google recommends using a web application monitoring solution and checking for bottlenecks in performance.
    Pro Tip: Read this report by Singlehop, Critical Ecommerce Infrastructure Needs, to learn nine things you need to focus on to keep your site performing well.
    Then tap into these resources:
    Yslow – to evaluate your site’s speed and get tips on how to improve performance.
    Google’s PageSpeed Tools – to learn more about performance best-practice and automate the process.
    Mar 2019
    Mumbai
    187
    Page Speed is the the time taken for a page to load as it used to improve website DA
    Jan 2019
    Ghaziabad
    205
    Page Speed is how fast your webpage load when someone tries to open it. Page Speed affects your SEO directly as the users left the website due to slow loading speed.
    Nov 2018
    1,853
    Page speed in SEO refers to the speed in which a page is loaded. Better load times (closer to zero seconds) are preferred by search engines overload times that take many seconds. Faster pages are said to have an increased potential of ranking highly for search queries compared to slower pages.
    Jul 2014
    100
    Page speed can be described as the “Loading time of a webpage” - how long your browser takes to respond to the webserver and loads the complete content of the webpage.
    Feb 2019
    293
    Page speed is often confused with "site speed," which is actually the page speed for a sample of page views on a site.
    Jul 2019
    86
    page speed means page load time , if the page load time above 3 seconds then it is considered bad as user might cancel the page and go back to search engine which will create increase in pogosticking, which will hurt the seo ranking and in order to prevent this from happening we need to make our page load time within 3 seconds. for this we can use image with less size or we can use less plugins or plugins which runs quickly and does not take too much time load
