Hello Dear,
Please Tell Me What is the primary difference between C and
Java ?
Hello Dear,
Java ?
JAVA is Object-Oriented while C is procedural.
Different Paradigms, that is. Most differences between the features of the two languages arise due to the use of different programming paradigms. C breaks down to functions while JAVA breaks down to Objects. C is more procedure-oriented while JAVA is data-oriented.
JAVA is Object-Oriented while C is procedural. Different Paradigms, that is. Most differences between the features of the two languages arise due to the use of different programming paradigms. C breaks down to functions while JAVA breaks down to Objects. C is more procedure-oriented while JAVA is data-oriented.
Web Development Companies in Bangalore | Best Website Design Company in Bangalore | Website Designing Company in Bangalore | Web Designing Company in Bangalore
C JAVA
C is a Procedural Programming Language. Java is Object-Oriented language.
C is more procedure-oriented. Java is more data-oriented.
C is a middle-level language because Java is a high-level language because translation of code takes place into machine language using compiler or interpreter.
binding of the gaps takes place between machine level language Java is an Interpreted language that is in Java, the code is first transformed into bytecode and that bytecode is then executed by the JVM
and high-level languages.
C is a compiled language that is it converts the code into
machine language so that it could be understood by the machine
or system.
(1) JAVA is Object-Oriented while C is procedural.
(2) JAVA is a high-level language while C is a low-level language.
(3) JAVA breaks down to Objects while C breaks down to functions.
(4) Java supports the concept of threading while C does not supports Threading.
(5) Default members of Java are private while Default members of C are public.
