What is Tier Links and how its work?
Tiered link building has been used in “black hat” SEO practices to manipulate backlinks and increase higher rankings. Tiered link building basically means you are building links from a variety of sources to your website
Tiered link building is all about guest posting on authoritative websites. You choose your first tier and the other websites point at it, while only the first tier points at you. This is a white hat technique that can put you on the first page of Google when done properly.
Tiered backlinking is a method to try and create “buffers” to your website. As an example, if you create one backlink to your page, but the page that backlink is on isn’t doing so well, it’s not going to help your page at all. The tiered backlink system works like a pyramid, where you build backlinks to your page and then build backlinks to those backlinks.
Tiered link building basically means you are building links from a variety of sources to your website. You can do this in several ways that are considered “white hat” tactics: Contribute content to higher ranking sites that are relevant to your own as a first tier.
