Results 1 to 11 of 11
    Sep 2019
    How to create Schema Markup
    How to Boost SEO by Using Schema Markup
    Sep 2019
    20
    Go to Google's Structured Data Markup Helper.
    Select the type of data that you plan to markup. ...
    Paste in the URL of the page or article that you want to markup. ...
    Highlight and select the type of elements to be marked up. ...
    Continue adding markup items.
    Sep 2019
    285
    Continue adding markup items. ...
    Create the HTML.
    Nov 2019
    2
    Use "Schema Markup Generator (JSON-LD)" and paste the code in your html page.
    Nov 2018
    1,033
    Schema.org is a joint effort, in the spirit of sitemaps.org, to improve the web by creating a structured data markup schema supported by major search engines. On-page markup helps search engines understand the information on web pages and provide richer search results.
    Jun 2013
    Forum
    4,691
    Schema markup, also known as structured data, is the language of search engines, using a unique semantic vocabulary. It is code used to more clearly provide information to search engines in order to understand your content.
    Cheap VPS | $1 VPS Hosting
    Windows VPS Hosting | Windows with Remote Desktop
    Cheap Dedicated Server | Free IPMI Setup
    Oct 2019
    2
    how to create schema data here
    Check the structured data here
    Apr 2016
    11
    schema markup is an code that you put on your website to help the search engines return more informative results for users. you can add schema code in header of web page. But according to the latest updates to Google Webmaster, schema markup is the most essential factor for website optimization. Schema markup helps get rich snippets on Google search results.
    Healthcare App Development Company
    Nov 2018
    1,033
