What is a good citation flow?
The best ratio seems to be 1. Average Trust to Citation Flow ratio should be 0.50. A high ratio will be delivered to an authoritative and trustworthy website. Like if the website has a Citation Flow much higher than a Trust Flow, there is no doubt that the website is hosting a bunch of low-quality links.
You might have plenty of backlinks but if they are not quality backlinks or are bad links, you will not have good trust flow.
Citation Flow is a number of predicting how influential a URL might be based on how many sites link to it. Trust Flow is a number predicting how trustworthy a page is based on how trustworthy sites tend to link to trustworthy neighbors.
█ Cheap VPS | $1 VPS Hosting
█ Windows VPS Hosting | Windows with Remote Desktop
█ Cheap Dedicated Server | Free IPMI Setup
Nearing the ratio of 1 is desirable. Average trust to citation flow ratio should be 0.50. More the authority and trustworthy the site, the ratio is higher. If the trust flow is greatly lesser than the citation flow, then it is clear that the site is having low-quality large amount of backlinks
real check stubs | make check stubs | paycheck stub online | check stubs online | check stubs generator | printable pay stubs | check stub maker | Real check stubs free | Make check stubs free | Make check stubs online | pay stub builder | paycheckstubonline | realcheckstubs | best pay stub generator | free check stub maker with calculator | free check stub maker | check stub maker free | free paystub generator | free paystub generator online | free paystub generator with calculator
Get your 1st stub free*
Free Check Stub Maker With Calculator | Pay Stub Generator | Free Paystub Generator | Online Pay Stub | Free Pay Stub Generator | Free Check Stub Maker | Paystub Maker | Create Pay Stub | Create Check Stubs | Create pay stubs | Paycheck stubs | Paycheck Stub online | Create a Pay Stub | Free Pay Stub Template | Check Stub Maker | Pay Stub Maker |paycheck stub maker
