Results 1 to 12 of 12
    Mar 2020
    Speed issues with the website
    We got a website hosted on Network solutions and offlate, we started facing problems with the page speed. The home page takes around 52 seconds to load. How to resolve the issue? do we need a different hosting provider? please advice.
    https://trilliantdigital.com - (this is not the domain in question)
    Nov 2019
    There are some tricks with which you can increase the speed. I guess you have have a lots of details on your website, you have to keep it clean. Search you tube and learn how to increase the speed. There are some particular trick you can apply.
    Photographer and Retoucher at background removal service helps ecommerce owners and commercial photographers edit their product photos that increase online sells.
    Jan 2020
    81
    hello,TrilliantD
    this fector is create Speed issues in your web site
    please remove the large image from home page.
    Use responsive images and compress your images
    I hope this will help to you
    Jun 2020
    73
    Most of the speed related issues are due to formatting of CSS File do look in them as well.
    Nov 2018
    1,728
    OPcache Isn't Enabled. ...
    Caching Issues Are Preventing Optimized Page Loading. ...
    Large Media Files Are Increasing Loading Times. ...
    Poorly-Written Scripts Are Conflicting With Other Site Elements. ...
    Your Site's Code Is Too Bulky. ...
    Missing Files Are Causing Errors. ...
    Plugins Are Weighing Your Site Down.
    Sep 2020
    59
    Render-Blocking JavaScript Is Delaying Page Loads.
    You're Not Using a Content Delivery Network.
    There's Excessive Overhead in Your Database.
    Your Site's CSS Isn't Optimized.
    Nov 2018
    1,348
    Render-Blocking JavaScript Is Delaying Page Loads. ...
    You're Not Using a Content Delivery Network (CDN) ...
    There's Excessive Overhead in Your Database. ...
    Jan 2020
    81
    We personally use Google's “Page Speed Insights” to check the website speed.
    It gives proper insights into where you can improve and what's the problem. So you can improvise and score good.
    There are other tools available in the market but I prefer google. So that improving those factor can increase the chances of better performance of our website in SERPs of Google.
    From Gtmatrix and Pingdom you can take suggestions and improvise that too but my first priority will be always Page speed Insights.
    Join the Space SEO Solutions by Experts & Digital Marketing Expert☆ to post SEO related questions and get Solutions by Experts.
    I hope this helps
    Jun 2019
    48
    You have to optimize the website pages for increasing the speed. Also, you can make use of GTmetrix or Page Speed Insights to check the page speed and also they will provide suggestions on where you should make changes to improve the speed.
    SupportSages - Helping web hosts grow, since 2009
    Check with us for white labelled server management plans!
    Our most popular plan - https://www.supportsages.com/per-server-support/
    Aug 2020
    1,290
    Server location. If you've ever made a long-distance call, you know that it takes longer to make the connection.
    Nov 2018
    1,728
    Sometimes websites load slowly because of the server. ... If there is an issue with the server, this will take longer than normal. The cause of slow servers usually lays with the web host. You could be having a slow site because you are hosted on a free web hosting.
