Results 1 to 12 of 12
    May 2023
    64
    How to split PST file into smaller parts?
    To split PST file into smaller parts using the Weeom PST Splitter Tool, follow these steps. Firstly, download and install the Weeom PST Splitter Tool on your system. Launch the application and select the PST file you want to split. Choose the splitting criteria, such as by size, by date, or by folder. Specify the desired size for each split file, and set any additional parameters according to your requirements. Once configured, initiate the splitting process, and the tool will automatically divide the PST file into smaller parts based on your chosen criteria. The tool ensures a seamless and efficient process, preventing data loss or corruption. After splitting, you can easily manage and organize your PST files, optimizing Outlook performance. This user-friendly tool simplifies the task of managing large PST files, enhancing overall productivity and maintaining the integrity of your Outlook data. Moreover, you can download its free demo version from the official website of Weeom Solution.
    Learn more: PST Splitter Tool
    You are seeking the best application for splitting huge Outlook PST files into smaller parts without losing any data. It suggests the ToolsCrunch Split PST Tool for Mac which is the best way to split Outlook PST files. To facilitate information retrieval, Outlook PST files are categorized by size, year, and folder. The following Microsoft Outlook versions are compatible with this software: 2021, 2019, 2016, 2013, 2010, 2007, and 2000. There are numerous features in this application. Using this software, you can split Outlook PST files into individual objects and folders. PST files in both ANSI and UNICODE formats are supported. There is no need to download Microsoft Outlook because this is split into Outlook PST files. It supports all Mac and Windows OS versions.
    Visit More:- https://www.toolscrunch.com/mac-split-pst.html
    2
    You can split an outsized Microsoft Outlook PST file into smaller components, creating average-sized PST files of the desired size. This tool is critical to saving you from overall performance troubles, statistics corruption, and capacity loss of crucial statistics. Outlook PST files can develop over time due to the accumulation of emails, attachments, contacts, calendars, obligations, and different statistics. Breaking them into smaller, doable components can improve Outlook's performance and simplify fact management. These pieces of equipment offer superior functions and make the splitting method quicker and more environmentally friendly. Some popular PST splitting tools ToolsBaer Outlook PST Split Tool for PST Split. By breaking the PST file into smaller elements, you lower the chance of facts being corrupted or lost. Easier Data Management: Managing smaller PST files is more handy, permitting you to organize and locate facts more effectively. Supports Outlook 2021, 2019, 2016, 2013, 2010, 2007, and 2002. Works on both Windows and Mac.
    Regular use of Outlook emailing increases the number of files that are being stored within PST files, which keeps on increasing. Sometimes the file can also get corrupted because of its size, which can additionally affect the overall performance of the e-mail application. But with the SameTools Split PST File, you can cut any large Outlook PST file into smaller sizes in just a few easy steps. The tool is constructed with superior strategies, with the aid of which it could cut up any massive, included, and ANSI file easily. This utility has a GUI interface, which makes it easy to use for both technical and non-technical users. Also, it is compatible with all home Windows versions.
    Apr 2024
    Split large Outlook PST files into smaller sections with the ToolsBear Split PST Tool to get control of the contents and reduce the danger of file corruption. Without losing any data or information, the application can split an infinite number of PST files into smaller portions based merely on size, year, and folder. Users can effortlessly split any huge Outlook PST file without any restrictions. This application is compatible with Outlook versions 2021, 2019, 2016, 2013, 2010, 2003, and 2000. All users can access the application's free trial version.
    156
    If you want to split PST files into smaller parts, then you should go with the professional Sysinfo PST Splitter Tool. It is a powerful tool that can split large PST files into smaller PST files. This tool provides you an option to enter the size of the resultant files according to your requirements. With its interactive GUI, you can perform this process without any technical skills. Additionally, it allows you to add multiple PST files which saves your time and effort. Moreover, this software is widely compatible and supports PST files of any Outlook version.
    103
    You can use the best and most reliable third-party software to split a PST file into smaller parts instead of the manual method, which is time-consuming and ineffective. The best option is to use third-party tools such as Softaken Split Outlook PST Software. This tool allows you to effortlessly split any size PST file into smaller pieces based on your preferences such as size, year, and folder. You just need to follow few simple steps to Split your PST file. The tool is compatible with all MS Windows versions. To know more, download the application's free demo version for free.
    Know More: https://www.softakensoftware.com/split-outlook-pst.html
    15
    Consider using the Advik PST Splitter Tool to split your large Outlook PST files. This software allows you to divide your PST files quickly and reliably. Many users struggle to manage their Outlook PST files because of their size. This tool is recommended for splitting large PST files into smaller ones. With this tool, you can efficiently organize your Outlook PST files into multiple partitions based on size, date, and folders. It is compatible with various Windows versions, including 11, 10, 8.1, 8, 7, XP, and Vista. You can download and try the free trial version to evaluate its performance. Both technical and non-technical users can use it easily due to its simple interface.
    119
    Regain PST Splitter can chop your bulky PST file into manageable pieces. Just launch the program, choose your PST file, and pick how you want to split it: by size, date range, or specific folders. Define the split criteria and the destination for the new files. Click split, and Regain will handle the rest, giving you smaller, easier-to-handle PST files.
    Jun 2024
    59
    DRS PST Splitter is a software tool that allows users to easily split large Microsoft Outlook PST files into smaller, more manageable parts. This is useful when Outlook data files become too large. The software has a user-friendly interface and can split PST files without data loss. It is a recommended solution for users who need to divide oversized Outlook data files into smaller, more manageable parts
    You are looking for the best tool for splitting large Outlook PST files into smaller parts without Outlook. Then the ToolsBaer MAC Split PST Tool is the best option. With its assistance, you can quickly split any size PST file into smaller ones based on your needs, according to size, date, year, and so on. This program allows you to split an Outlook PST file of any size without any limitations or restrictions. Users without any technical knowledge can use this software. This application supports Outlook 2021, 2016, 2013, 2010, 2007 & 2003. With this software, all kinds of Microsoft Windows versions work flawlessly. Download the application's free demo version to learn more.*****
    Visit Here - https://www.toolsbaer.com/pst-split/
    Jul 2024
    New York, USA
    You should know that when the PST file size becomes very large, it takes a long time for us to access and open the file. So, in this case, you can use MailsDaddy PST split tool. It is an application that splits multiple or large PSTs into smaller files at once, even without the MS Outlook application.
    Get more details: Best PST Break Tool
