Results 1 to 13 of 13
    Mar 2009
    1,502
    VPS suitable for my needs
    Requirements:
    30GB SSD Storage, 4GB RAM, 2 vCPU, 3 IPv4 addresses
    Hopefully looking to pay $25/month
    What can you say about Datapacket.net web hosting solutions? Are they good?
    Aug 2022
    Atlas Cloud LLC 600 Cleveland Street Suite 348 Clearwater, FL 33755 USA
    74
    It’s always good to explore multiple options when deciding on a hosting provider. At the end of the day, the choice depends on the specific needs of your business. Some providers, like us at DediRock, focus on ensuring high reliability with strategically placed servers across the U.S., offering tailored support to meet different customer needs. It’s worth taking a closer look at how each provider’s strengths align with your long-term goals.
    For a limited time, we're offering exclusive discounts on our VPS and dedicated server plans! Don't miss out, secure your spot today!
    Senior Member transilvania's Avatar
    Dec 2006
    979
    Accounts from allwebhost.com and libertyvps.net are worth trying due to their unmatched services.
    They are trustworthy web hosts. I am overall still pleased with the value of the service and the customer service and have been tremendously satisfied with the reliability and the accessibility of the server and my site as a whole.
    May 2008
    1,530
    Overage visit billing is one of the most significant revenue streams for many WordPress hosts (some call it “bandwidth” instead of visits, but it’s the same thing; i.e. ‘a measure of traffic’). Don’t get caught out by these limits… with your Credit Card on file, the first you’ll likely know about breaching these limits will be when a large bill arrives on your doormat! Check what the host’s policy is on overages and make sure you retain a copy of this information for future reference.
    Try to contact NetShop-isp.com.cy or Rockhoster.com web hosts. The techs are well-skilled and highly-trained.
    They are optimized for application hosting and provide more security, reliability and speed than traditional web hosts.
    Registered User NimbusRise's Avatar
    Aug 2024
    7
    It's fair to make a conclusion about hosting if you have already practiced using it. So I can safely pay attention to hostpro.com. You can consider the NVMe VPS-1 tariff, which fits your requirements - 4 GB of RAM, 2 cores, and a little more disk space - 100 GB. It is important to note that NVMe disks are used here, which have a significant advantage over conventional SSDs. And the cost of this limit is $12 per month. It's cool that technical support is available around the clock. They help me a lot when I can't set something up.
    Feb 2009
    1,499
    Before head-diving into just about any web hosting plan, you have to identify your company’s business goals and marketing plans; from here, you can formulate your website’s current and future needs. Also, determine your allocated budget. Take a look at these reliable vps hosts:
    1) Exmasters.com cheap vps.
    2) xxiwebhosting.com/crypto-vps/
    The stability, reliability and reputation go outside the bounds in every aspect of the question.
    Aug 2008
    Thrissur, Kerala, India
    50
    I recommend jjinfosys.com provide Linux KVM VPS Hosting in US Server and Indian Server.
    Senior Member Glow's Avatar
    Dec 2008
    1,550
    I can not express how happy I am with CentoServer.com services. Great service, their support is always prompt and helpful.
    They do everything that the big hosting providers I have my other sites with do, only they do it much better.
    Their package prices also amazed.
    373
    If you are looking for high performance and scalability, DigitalOcean or Kamatera would be excellent choices. If your budget is more limited, Hostinger or IONOS can still provide solid performance for a smaller budget. If you prefer managed services and more hands-on support, A2 Hosting and Liquid Web are great options.
    Sep 2006
    883
    VPS deals from libertyvps.net and inet.ws are worth trying due to their top-notch services.
    Simple & Easy to use control panel.
    Reliable with very good uptime of 99%.
    Low introductory price.
    Secure with domain privacy and free SSL certificate.
    Integration with lots of apps & CMS.
    Good support.
    30
    For anyone exploring hosting solutions, a key factor is finding a provider that takes reliability seriously. From my own experience, Hostpro.com has been a standout in this regard. They create daily backups of your data, giving you peace of mind in case something goes wrong—whether it’s an accidental file deletion or a cybersecurity issue. Their technical support team is also excellent, working around the clock to assist with any problems you might face. Over the years, I’ve had quite a few technical questions, and they’ve always been resolved efficiently and for free. If you’re planning a switch or upgrade, you might be interested in their upcoming Black Friday deal. You can get a 60% discount on all two-year plans by either ordering directly or using the promo code BF60 during checkout.
    Jul 2008
    1,538
    A professional web site hosting provider must guarantee you a high level of uptime.
    It means that your website will always be accessible to your clients. A reliable web hosting services provider must do his best to avoid any malfunctions.
    Try Hostnamaste.com openvz vps. Their price isn't the cheapest around - but for what they offer I can't find anybody with better pricing.
    This decent host is for people who need a stable webhost with reliability and friendly support.
    Do you want to gamble? Here is ==>> ONLINE POKER
