Results 1 to 5 of 5
    Apr 2014
    india
    390
    Two domain extension for my domain with same contet?Is this raise duplicate issue?
    I have two domain extensions for my main site .ie and .com version. Like Example.com (This is my main site) and example.ie (itís not indexed in Google).
    My site is targeting not only in Ireland but also in UK and the .com version of site is well indexed in Google and I don't want to prefer that .ie version instead of .com version.
    Only url is different, content and everything is the same. Is 301 redirection is needed for .ie version or do I want to add canonical tag to my .ie domain. Is this is a must?
    or can I hide the .ie version using robot.txt?
    Senior Member schwa's Avatar
    Mar 2011
    Chengdu, Sichuan, China
    427
    I guess so. Tho Google doesn't index your another website but I think it will index it sooner or later. Since you have 2 domains, why not add some unique contents for each one. And use one site to give the other site some back links, which will be good for your SEO. However, the premise is you should let Google believe that these 2 sites are not similar.
    My name is Linda Chow, I am running a small online clothing store where you can find and shop sweet Lolita dress, Gothic Lolita dress and many other lolita accessories | My New Store: Cheap Latex Clothing
    Feb 2014
    delhi
    545
    if another two domain are redirect on the main domain that is beeter and you can also block two domain by robots.txt file. no create duplicate issue .
    Jun 2014
    107
    You can block the ie domian. However, i believe that it would be ideal to use 301 redirections. As it is the effective strategy that can pass link juice to the respective domain completely. You can block the ie extension using webmaster so that its not indexed in google, also see that you use 301 redirections.
    Jul 2012
    Bangalore
    430
    Quote Originally Posted by rohit View Post
    I have two domain extensions for my main site .ie and .com version. Like Example.com (This is my main site) and example.ie (it’s not indexed in Google).
    If you are using the same content for two different domain URL,any one of the website would get low search ranking due to Google Panda Algorithm.So just make the unique content for your two websites.
