Page 1 of 2 12 LastLast
Results 1 to 15 of 23
    Mar 2009
    2
    11 search engine optimization tip
    The title tag is critical. Itís important not to overcomplicate your design and technical approach with things such as Flash, Java, frames and dynamically built websites.
    The title tag is the single most important piece of content for people who search.
    1. Keep it short: Donít have more than 60 characters (with spaces), which is roughly 8-10 words.
    2. Lead with the most important careword for that particular page. Always start off with what is specific about the page and move to what is general. Many websites begin their title with their brand or organization name, and then follow with what is unique about the page. (This is a very common mistake, so check out your website.)
    The description tag is recommended
    The description tag is not nearly as important as the title. However, it does have some value. Write it as a summary and keep it under thirty words. It should be written in a compelling, clear manner.
    Light pages, and lean, quality HTML
    The less HTML code you have, the better, as it makes it easier and faster for the search engine to index your page. Aim for a total page weight of 50 KB for any page (thatís including graphics). Certainly, anything over 100 KB is going to be slow, and some search engines donít like pages that are over 100 KB.
    Have a site map/index
    People like site maps/indexes, and so do search engines. Make sure that the site map is available from the homepage, that it is presented in a text-based format, and that it is kept up to date.
    Avoid Flash
    Iíve nothing against Flash design except for the fact that I generally detest it. Itís such a waste of time; fourth rate TV advertising by people who will never get the chance to do a real TV ad. Search engines donít like Flash either, and find it very hard to index Flash-based pages.
    Build your website in static HTML
    You donít need a ďdynamicĒ website unless you have dynamic content, such as airline seat availability and pricing which needs to be dynamically published from a database because it constantly changes. You may store your website in a database but youíre better off publishing it as a static HTML website. Itís cheaper, the pages will download faster, and search engines will find it easier to comprehensively index your website.
    Avoid PDFs
    One of the sure signs of a badly managed website is that it has lots of PDFs. Publishing content in PDF is usually a shortcut. Search engines have got better at indexing PDFs but it is still recommended that you publish a heading and summary in HTML.
    Avoid frames
    Frames are a very bad idea.
    Watch your JavaScript
    Any links that you have in JavaScript should also be published in HTML, otherwise the search engine wonít be able to follow those links. Rollovers are cool but they cause nothing but problems, so unless you have a brilliant technical team, avoid them.
    Alternative text
    As a rule you should have alternative text for every single image. However, the only alternative text that search engines recognize is for those images that are linked. Make sure you use descriptive, careword-rich text.
    Keyword tags
    Over the years, some websites tried to trick search engines by stuffing keyword tags with lots of popular words. Because of this, most search engines give very little value to keyword tags
    Jan 2009
    107
    Don't do just copy/paste from other sources. Put your own words in it too.
    May 2009
    179
    The tips were good and I do agree with the Title and description tags. The other thing though is that you can't forget that keyword tag is still good. Its just that you don't want to many of them nor do you want to little.
    Jan 2010
    These 11 seo tips is best of me... thanks for sharing... meet again...
    Feb 2010
    9
    Thank you for sharing this information, but i think you are really doing copy/pate ..
    Jan 2010
    23
    Thanks for the really helpful tips regarding website optimization.
    Feb 2010
    This is very nice information to help to optimization of your website according to the search engine.
    Thanks.
    May 2009
    Oh wow! That's really a very great post. Its very informative for me. I 'll try to follow these tips. Thanks for sharing such a nice post.
    Jan 2010
    4
    "Nice article really informative!! SEO is very long
    process .Thanks for the great tips! That's good idea.Thank you
    Guest Moderator ~ServerPoint~'s Avatar
    Nov 2007
    1,846
    adriyanna62, would you mind use UCP for signature and stop posting fluffy posts?
    ServerPoint.com - a true hosting company offering online presence solutions since 1998
    Web Hosting, colocation, dedicated servers, Virtual Private Server (VPS) hosting
    Wholly owned multi homed network, servers and facilities
    Dec 2009
    40
    Thanks for taking the time to post such a detailed and informative
    May 2009
    157
    Copy/paste or not it's a good info for me it picked up new ideas. Thanks!
    Jan 2010
    2
    Its really a very good info. I didn't know about the most tips. I am new to SEO field. I 'll try to follow your tips. I hope that these tips 'll help me a lot in getting good SERP listing. Thanks for the info buddy.
    Dec 2009
    26
    Hi
    Thanks for this ,i will follow to you.
    Feb 2010
    7
    Hi Friends..!!!
    Thanks many more for 11 tips on seo..meet again.
    Organic Seo in India | Ethical Seo Company India
