how do we optimize speed of website?
You can use service of Google to optimize the speed of your site.
There are many things you can do to improve the page speed.
Please check the site response time in http://tools.pingdom.com/fpt/ and https://gtmetrix.com
Please read the suggestions provided in there and you will see improved page speed.
█ ServerPoint.com, hosting thousands of customers since 1998
█ Dedicated Server Hosting - Cloud VPS Hosting - Web Hosting
█ Las Vegas / Silicon Valley / Dallas / Ashburn / Amsterdam / Singapore
To Follow These,
Compress Your Images Even Further
Utilize Console.log() to Debug
Javascript Compression Services
CSS Compression Services
Compressing images, removing unwanted material from web page or unwanted code can help in improvising the load speed of a website.
Ways to Speed Up Your Website:
1. Minimize HTTP Requests
2. Reduce server response time
3. Enable compression
4. Enable browser caching
5. Minify Resources
6. Optimize images
7. Optimize CSS Delivery
8. Reduce the number of plugins you use on your site
Thanks for the information sharing !!
you can install the plugin wp super cache
Usually by optimizing query and reduce number of images and size of images. Use Content delivery network(CDN) for images.
Most probably SQL queries should be culprit.
█ InnoHosting, Performance Web Hosting || US: 1-888-522-INNO UK: 0800 612 8075
█ Web Hosting - Virtual Servers - Managed Servers - Application Hosting
█ Reseller Hosting with WHMCS & Preloaded KB | SSL | activGuard | End User Support
█ Nginx / CloudLinux / Idera Backups / True 24x7 Support / 10+ Years in Business
By Reducing the size of images or uploading them on MaxCDN by using server side and client side caches. By increasing your server RAM size and Bandwidth. If your site is on WordPress you can check this guide Ways To Speeup Cloud-Hosted WordPress Site
Load Test Your Site
Second it is important to load test your site to see what might be causing bottlenecks. Below are few tools which can help test your website. These can also be very useful if you are trying to scale out a platform.
5. Minify Resources
6. Optimize images
8. Prioritize above-the-fold content
9. Reduce the number of plugins you use on your site
10. Reduce redirects.
. Reduce redirects.
Here is something you might interested in:
webdesignerdepot.com/2014/12/how-to-optimize-your-website-for-speed-and-why-you-still-should/
You can install the cache plugin and
1, Remove unwanted images
2, Remove unwanted files
