Difference between indexing and crawling?
Indexing is adding your website in google that is when people search your website name is visible.Crawling is google crawls into the website many times per day to check if there is any new content added into the website after it recognizes the new content it is then saved into the main google.
In layman's terms, indexing is the process of adding webpages into Google search. Depending upon which meta tag you used (index or NO-index), Google will crawl and index your pages. A no-index tag means that that page will not be added into the web search's index. By default, every WordPress post and page is indexed
Crawling means the search engine optimization robot crawl or fetch the web pages while Indexing means search engine optimization robot crawl the web pages, saved the information and it appear in the search engine optimization.
Crawling - While searching any information in the search engine using a particular keyword, the search engine spider/bot find any meaningful information on any page related to that keyword this process is termed as crawling.
Indexing - Indexing means the information searched by many people and find it useful then google stored it permanently in the databases.
People often get confused with the two integral terms of Search Engine Optimization (SEO) - Crawling and Indexing. Both are the part of the steps that any search engine follows to rank & display the website in Search Engine Result Pages (SERP). Many technocrats even after working for so many years in IT industry could not distinguish the difference between these terms, so understand it very carefully.
Crawling-: When any search engine sends their bots or spiders or crawler to visit the whole website by following the links on each web page, that process is known as Web Crawling in technical terms.
Indexing-: When any search engine basically list your web page (which is mostly the keywords and not whole content!) and stores it in their massive data centers so that it can be utilized later, that process is known as Indexing in technical terms.
indexing is adding your website to google
crawling is process that google sent boots or spider to crawl the website
In SEO, indexing and crawling are usually done by web crawlers of search engines. Crawling is the method in which web crawl visits and crawls your website and indexing is the method in which web crawlers saves the website in its database after crawling the whole website and marks it visible on search engine.
One perfect example of terms that are incorrectly used synonymously is Crawling and Indexing. Whether the writer understands the difference or not, in many SEO articles it leads the reader to believe the two words mean the same thing. They most definitely do not.
Crawling is the process of storing the information of the web page of the website. Indexing is the process of listing the crawled information on the SERPs.
