Results 1 to 2 of 2
    Mar 2022
    67
    Issues with large font in mobile mode
    This site's OK on the desktop
    But when I test it in mobile mode, the 'London and Surrounding' bit doesn't fit on the page and the lower scroll bar appears.
    If I reduce the font-size of <h1>, then the page behaves.
    If I use "overflow:hidden;" in .magcontainer, the large font still is an issue.
    What in the CSS would cause <h1> to do this?
    Nov 2020
    A likely cause is the H1’s fixed font size plus default margins or nowrap behavior causing the container to exceed the viewport. Check width, padding, white-space, and box-sizing before using overflow:hidden.
