    281
    Best Solution to Delete Duplicate Items in Outlook
    One of the best and most dependable methods to delete duplicate items in Outlook PST format is to use a professional CubexSoft Outlook Duplicate Remover. This tool has a variety of cutting-edge features that enhance how well the de-duplication process functions as a whole. People with various levels of technical expertise may use the software because of its user-friendly interface, and because it operates without errors, the risk of data loss is reduced. This program is free of viruses. Any quantity of files can be removed here without compromising the integrity of the data. It needs a complete data de-duplication guarantee.
    Read More: Removing Duplicate Items in Outlook
    Sep 2023
    47
    I want to say that the best solution to delete duplicate Items in Outlook with the help of Softaken PST Duplicate Remover Software is the safest and best tool that can help remove duplicates from PST files and it allows users to remove all duplicate emails from a mail folder in Outlook. To remove duplicate email items from Outlook data files It is designed to eliminate duplicate contacts, tasks, attachments, emails, and other objects from PST files using extremely sophisticated capabilities. This utility supports Outlook 2003, 2007, 2010, 2013, 2016, 2019, 2021, etc. versions file and with this app, users can easily handle bulk PST files without any file size restrictions here to delete duplicates. Outlook users can operate this computer software without any technical issues and download this program on Windows 10, 8, 7, XP, Vista, etc. This duplicate remover provides a free trial to examine the tool.
    Jan 2024
    31
    The best solution to delete duplicate items is Outlook, users want the best working tool to delete duplicates so I recommend the MailsClick PST Duplicate Remover Tool this is the best solution to find PST file duplicate contacts, emails, attachments, calendars, etc. Delete them without creating any changes inside the PST file data. This application is helpful at that time when users have bulk duplicate data and want to delete them without any loss of original data so should use this utility without any fear of data loss. This application is well performed to maintain email properties and file formatting while deleting duplicated data of PST files. Users can install this utility and it works with all MS Outlook files, including 2021, 2019, 2016, 2013, 2010, 2007, 2003, and 2000 versions. The tool has no requirement for Outlook, which means that users can perform duplicate deleting tasks without Outlook. Users can download this application on Windows 10, 7, 8, XP, Vista, etc. to remove duplicate PST folders and new users will get a free trial to examine the application. Read more: https://www.mailsclick.com/duplicate/pst/
    Jun 2023
    89
    MigrateEmails Duplicate Remover for Outlook is the best tool to remove duplicate items from Outlook effortlessly. This tool enables removing all duplicate items like emails, contacts, calendars, etc in bulk without disrupting data integrity. Its simple GUI makes it easy to use by all kinds of users. The Date filter of this software helps to remove duplicate items of a selective date range.
    Apr 2024
    22
    If you are looking for a way to delete duplicate items in Outlook, I suggest that you try TrustVare MS Outlook PST Duplicate Remover Tool. With the help of this application, you can easily remove all duplicate items from Outlook, such as files, emails, attachments, tasks, journals, notes, and many more. Also, this user-friendly software is so easy to use; just follow the simple steps, and all duplicate items will be removed. After deleting duplicate items, users can save data at their desired location. This program runs smoothly with all MS Windows editions. Additionally, a free demo version of this software is also provided by the program.
    118
    The Regain Outlook Duplicate Remover Tool is an excellent solution for managing duplicate items in Outlook. This tool efficiently scans your mailbox and eliminates duplicate emails, contacts, calendar entries, and other Outlook items. Its user-friendly interface makes it easy for both novice and advanced users to clean up their mailboxes quickly. By using this tool, you can significantly improve your Outlook performance and reduce unnecessary clutter. Try the Regain Outlook Duplicate Remover Tool for a streamlined and organized email experience.
    Oct 2025
    30
    The best duplicate item remover for Outlook is the SysTools Outlook Duplicate Items Remover. It efficiently detects and removes duplicate emails, contacts, calendars, tasks, notes, and journals from PST/OST files without affecting original data integrity. The tool offers options to remove duplicates within folders or across folders, applies smart filters (date, subject, sender, etc.), and supports all Outlook versions. Whether duplicates are created due to syncing, importing, or profile issues, SysTools ensures a clean and organized mailbox quickly and safely — making it the most reliable choice for Outlook users.
    36
    There are many best solutions to delete duplicate items in Outlook, but I suggest the best tool for deleting duplicate items in Outlook files. You can try the GainTools Outlook Duplicate Remover, is automatically scans multiple Outlook files like emails, contacts, calendar, notes, tasks, events, etc, finds duplicate items and deletes them without losing important data. The software manages a huge number of duplicate Outlook files without the help of any other application. It has an easy interface for non-technical users, and they can simply operate it without any technical skills. It runs on all Windows OS versions like 11, 10, 8.1, 8, 7, and is also compatible with Outlook versions. You can try the free trial before purchasing this tool.
    Visit here: https://www.gaintools.com/pst/duplicate/
    May 2022
    160
    The problem: Repeated imports, sync errors, and merged PST files leave Outlook full of duplicate emails, contacts, and calendar entries. Deleting them by hand takes hours and risks removing the wrong item.
    The fix: Shoviv Outlook Duplicate Remover scans a PST file and flags items that match on criteria you choose, such as subject, sender, date, or attachments.
    How it works:
    *Select the matching criteria
    *Run the scan and review the flagged items
    *Delete them or move them to a separate folder
    The result: A smaller PST file, faster searches, and an organized mailbox, with the folder structure untouched.
    A Email Migration Consultant at Shoviv Software
