Page 1 of 3 123 LastLast
Results 1 to 15 of 41
    82
    Most Recommended OST to PST Converter
    Converting OST to PST files can be done using various methods and third-party tools. Here's a straightforward approach using Microsoft Outlook itself:
    Method using Microsoft Outlook:
    Open Microsoft Outlook:
    Ensure that you have Microsoft Outlook installed on your system.
    Create a New PST File:
    Open Outlook and go to "File."
    Select "New" and then choose "Outlook Data File."
    Choose "Office Outlook Personal Folders File (.pst)" and click "OK."
    Select Items to Move:
    In the Navigation pane, right-click on the mailbox or folder you want to export.
    Choose "Copy Folder" or "Move Folder" option.
    Choose the PST File:
    In the "Copy Folder" dialog, select the PST file you created earlier.
    Click "OK" to start the copying or moving process.
    Finish the Process:
    Depending on the size of your mailbox, this process may take some time. Once completed, you will have a PST file with the selected items.
    Third-Party Tools:
    If you prefer a more automated or advanced solution, third-party tools can simplify the process. One such tool is the Kernel for OST to PST Converter. Here's a general guide:
    Download and Install Kernel for OST to PST Converter:
    Download and install the tool from the official website.
    Launch the Software:
    Open the Kernel for OST to PST Converter.
    Select the OST File:
    Use the "Browse" button to select the OST file you want to convert.
    Choose Conversion Options:
    Select the conversion options based on your preferences, such as file format (PST) and other parameters.
    Specify Output Location:
    Choose the destination where you want to save the converted PST file.
    Initiate the Conversion:
    Click on the "Convert" or "Start" button to begin the conversion process.
    Finish and Verify:
    Once the conversion is complete, you can locate the PST file in the specified destination and verify the data using Outlook.
    https://www.nucleustechnologies.com/...converter.html
    I recently tried the demo version of the Cigati OST to PST Converter to convert my Offline OST file into the Outlook PST file format, along with all its attachments. The software's performance in terms of file conversion is very smooth and fast.
    274
    You can also try CubexSoft OST to PST Converter for Mac & Windows Tool to convert your all Outlook offline OST file into Outlook PST file format with complete details and information without Outlook installation. This software comes with so many unique and helpful features for users to easily batch convert OST to PST with attachments without any problem. It was workable on both Mac OS and Windows OS including Windows 11.
    Jan 2024
    28
    To convert OST to PST files, one should try use Weeom OST to PST Converter tool. It is a secure solution for OST users to convert into multiple formats. Using this tool, users can convert OST files into PST, EML, and MSG formats.
    Read More: How to Convert OST to PST
    May 2022
    148
    1. Launch Shoviv: Open the Shoviv OST to PST Converter tool and locate your OST file.
    2. Choose Conversion: Select "OST to PST" and pick your desired output PST format.
    3. Convert & Optimize: Hit "Convert" and let Shoviv work its magic. It automatically optimizes PST size and retains folder structure.
    Read more: ost to pst
    Bonus Tip: Shoviv lets you filter emails by date or sender before conversion for a targeted transfer.
    140
    It's always beneficiary to use an effective and reliable OST to PST Converter for converting entire data of OST files to PST format. In this regard, I would recommend you to use only ZOOK OST to PST Converter tool. It is completely professional and powerful tool to convert unlimited OST files to PST format including emails, contacts, calendars, notes, etc. This tool comes with wide range of features and user-friendly interface, which makes it suitable to convert OST files.
    118
    Regain OST to PST Converter is a reliable and user-friendly solution for individuals facing OST file-related challenges in Microsoft Outlook. Its feature-rich design, ease of use, and compatibility make it a valuable asset for recovering and converting OST files efficiently.Users can explore the functionalities of Regain OST to PST Converter through a free trial version. This allows them to assess the tool's capabilities and decide whether it meets their specific needs before making a purchase.
    12
    The ToolsCrunch Mac OST to PST Converter Tool is the most recommendable solution for all technical solutions to convert complete offline OST data files to PST format without facing technical errors. If you want a converter that will work properly while converting OST to PST, here is one of the most secure and effective ways to convert.ost to.pst files without using MS Outlook or an Exchange server. This utility offers simple methods for converting offline ost files, as well as a basic graphic user interface that allows non-technical users to quickly interact with its components. It program offers a free trial in which customers can convert a few OST files to PST with no alterations. This is a simple solution for non-technical users who don't have any technical knowledge to understand the process. It is specially designed for the Mac operating system but it works on Windows OS as well.
    Oct 2021
    40
    SysBud OST to PST Converter tool helps you to convert OST files to PST file format. The software repaired corrupted, damaged, and inaccessible OST files to PST file format. The software needs on 4 simple clicks to move OST data to Outlook PST format. You can install the software on all Windows OS and move items from OST to PST.
    183
    Another most recommended OST to PST converter is the CloudMigration OST to PST Converter. It is the most reliable tool to convert OST files to Outlook PST files. Experts also recommended this tool for secure conversion of OST files to numerous file formats. Using this tool, users can exclude the attachments and remove duplicate emails. It can also convert OST files in bulk without using the Outlook application. This tool maintains the data integrity of the folder and keeps your OST file data safe throughout the process. Additionally, it can transfer the OST files to Gmail, Yahoo Mail, Office 365, etc. You can use this software with any Windows version.
    130
    If you are looking for the most recommended OST to PST converter software, So, I suggest the best converter software for converting OST files to PST format. You can give Softaken OST to PST Converter Software a try. With the help of this application, you can easily convert your bulk OST file to PST file format, no matter the size of the OST file. The tool is so efficient in its work that without any limitation, you can easily convert an OST file to a PST. The utility is compatible with all MS Windows editions, so you can easily run this program smoothly. You can also try the free demo version of this program to learn more.
    There are lots of OST to PST converter software programs available on many different platforms. So, I suggest you the most recommended OST to PST Converter Software. You can give ToolsBaer the OST to PST Conversion Software a try. This tool enables users to control data conversion. It converts OST files to PST and saves the output to a location specified by the user. It might be any suitable folder, new or old. Users of Windows 10, 8, 8.1, and 7 can easily use this app. It performs quickly on both 32- and 64-bit systems. The utility is also compatible with all upgraded versions of Microsoft Outlook, such as 2003, 2007, 2010, 2013, and others. A free version of this program is also available.
    Jul 2023
    Another easy yet powerful tool to convert OST into PST file format is Magus OST to PST converter. It is a very simple and efficient tool to export large OST files into PST format keeping the folder structure intact.
    62
    Corbett OST to PST Converter is the most recommended application as completely designed with the presence of experts and also can easily restore and convert damaged, corrupted and overlarge size OST file. You can also take benefits of filter option to convert necessary data as per date range, subject, sender and recipients etc.
    Mar 2023
    61
    For OST to PST conversion, you should try MacMister OST to PST Converter for Mac Tool. It’s a famous and most reliable solution for importing OST files to PST format along with all emails, contacts, tasks, notes, attachments, journals, and calendars. It can export single or bulk Offline OST files to PST files at once without Outlook installation. To check out its working procedure and functions, users can try a free pack of this utility.
