Page 1 of 3 123 LastLast
Results 1 to 15 of 44
    143
    Most Reliable Method or Tool to Convert MBOX Files to PST Format
    MBOX files can be easily convert into Outlook PST format with an attachments using a professional's recommended ZOOK MBOX to PST Converter software. This tool offers to batch export MBOX to PST in a single process. The software have intuitive and user-friendly interface so that users can efficiently convert MBOX files to PST without any error. It is fully supportable to 30+ MBOX based emails clients and compatible with all latest and old versions of Outlook. It is most reliable method to convert MBOX files to PST format without any extra efforts.
    Jan 2024
    Mailvita MBOX to PST Converter Tool is the most reliable method or tool to convert MBOX files to PST format. Mac and Windows users can easily work on this application. This tool converts bulk MBOX files to the Outlook PST file format. It supports all email clients of MBOX files, such as Apple Mail, Thunderbird, Spicebird, LiveMail, Mulberry, OperaMail, SeaMonkey, MozillaMail, ClawsMail, Cone, etc. This software supports all MS Outlook versions, including 2021, 2019, 2016, 2013, 2010, and 2007. This software supports all Mac and Windows OS versions. If you really need it, you can try it once and check out the free demo version.
    82
    Facilitating versatile data export, Kernel for MBOX to PST Converter offers users the option to export information in various file formats, including EML, EMLX, MSG, PST, etc. A free trial version is available, supporting all versions of MBOX and PST. The tool ensures efficient conversion of large Thunderbird data from MBOX files to Outlook PST formats, encompassing mailboxes with emails, images, chats, attachments, and more. This Thunderbird to Outlook Converter stands out as a dependable solution for swiftly converting both single and multiple MBOX files into PST format simultaneously. https://www.nucleustechnologies.com/mbox-to-pst.html
    May 2023
    87
    Weeom MBOX to PST Converter Tool is a reliable software designed to facilitate effortless conversion of MBOX files to PST format, ensuring efficient migration across email platforms. This tool has an intuitive interface, it simplifies the process for users, allowing them to convert multiple MBOX files to PST in a few clicks. The tool preserves email metadata, attachments, and folder structure during the conversion, ensuring data integrity. It supports various MBOX-based email clients like Thunderbird, Apple Mail, and others. Users can export their MBOX files to Office 365 and Live Exchange Server mailboxes with ease. Moreover, this tool offers advanced filtering options, enabling users to selectively migrate emails based on criteria like date range or specific folders. And capable of converting MBOX files to PST, EML, and MSG file formats.
    Read more: Convert MBOX to PST
    151
    Get the MBOX to PST Converter application. All users, technical and non-technical, can export MBOX emails in PST file format through the software's GUI interface. You can export multiple MBOX emails to Outlook PST file format without any errors or data loss, saving you time. Using our MBOX to PST Converter Software, you can easily convert MBOX to PST files as well as other file formats like EML, EMLX, and MSG. It is designed to help users convert data from MBOX files to Outlook PST format and has a graphical user interface. It is compatible with all Windows operating system versions, including Windows 10, 8.1, 8, 7, XP, Vista, and all versions listed below.
    May 2022
    150
    For the same task, I refer Shoviv MBOX Converter tool. With its reliable conversion and easy-to-use features you can automate the conversion process. You can Export the MBOX file in PST, MSG, and EML file Format, you can even migrate MBOX files into Office 365 and Exchange server.
    118
    Regain MBOX to PST Converter stands as the pinnacle of reliability when it comes to transforming MBOX files into PST format. Its flawless performance and user-friendly interface position it as the prime selection. Rely on the efficiency of Regain for a conversion experience free of complications. Opt for Regain – the foremost tool in the MBOX to PST conversion domain.
    36
    To convert MBOX files to PST format try the best BetaVare MBOX to PST Converter Tool to convert MBOX files to Outlook PST format with attachments. Both technical and non-technical persons can utilize this with ease. MBOX files just hold emails and attachments, but Outlook PST files retain contacts, emails, notes, messages, calendars, and other data. Because of its small size, users can easily store this application. MBOX file format for every email client is supported. You can easily run this application on any Windows OS version because it is compatible with them all. There's also a free trial version accessible. It is simple and quick to convert an MBOX file to a PST file.
    May 2012
    894
    never tried mentioned tool for converting Convert MBOX Files to PST Format.
    The method will depend upon your specific needs and priorities. check out some of these tricks for better breakdown,
    1. use thunderbird or outlook, that saves MBOX files as EML files, later import them into Outlook
    2. there are some third party tool available for fast solution
    3. manual method is quite easy for frequent or large file conversions.
    MilesWeb :: Your Hosting, Our Responsibility!
    Secure Virtual Environment | Dedicated Servers | eCommerce Hosting | WordPress Hosting
    Oct 2021
    45
    If you want to convert MBOX to PST format then you need a powerful solution like MailsDaddy MBOX to PST Converter tool. The software interface is designed to export bulk MBOX files to Outlook, Office 365, EML, etc. The user does not need any technical experience to move emails and other items from MBOX to PST format. The application has lots of options like preview, batch migration, filter conversion, selective migration etc. You can also download free demo edition of the software and move few items from each folder.
    Get more info: MBOX Converter for Outlook
    Utilise professional program CubexSoft MBOX to PST Outlook Converter to error-free migrate unlimited MBOX data to Outlook PST database to various popular desktop and cloud application. The software is supportable on all the Windows editions such as 11, 10, 8, 7, 8.1, Vista, XP, etc. The utility keep mail properties of MBOX files intact and also retains original folder hierarchy. The tool is programmed with multiple advance function for smooth conversion of MBOX into Office 365, Gmail, PDF, PST, MBOX, MSG, Exchange Server and many other.
    The demo edition is also available to guide users in exporting Outlook PST files efficiently and easily. You will get free export of up to 25 PST files into desirable output option.
    Read More: MBOX Converter
    Convert MBOX files to PST format. I suggest the Softaken MBOX to PST Converter Tool, which converts several MBOX files to Outlook PST files. Users can easily install this little application. Users can try out the free demo version. Thunderbird, Mac Mail, Eudora, PocoMal, GNU, Postbox, SeaMonkey, and other email clients are all functional. It fully supports all Windows operating systems. After conversion, MBOX data can be opened in any MS Outlook version, including 2019, 2016, 2013, 2010, and 2007. You can convert MBOX files to Outlook PST files without size limitations.
    Jun 2023
    89
    MigrateEmails MBOX Converter Tool is a reiable solution to convert MBOX to PST in bulk. This tool ensures complete emails transfer from MBOX to PST without any data loss. Its user-friendly interface makes it easy to use by both technical and novice users. Moreover, users can also convert MBOX to PDF, EML, EMLX, CSV, and more using this tool. The MBOX file migrator maintains data integrity throughout the process.
    183
    If you're looking for a reliable solution to convert MBOX to PST, then you should try using the Sysinfo MBOX Converter. It is the most reliable and secure solution to convert MBOX files into different file formats. This tool is well-equipped with advanced features that enhance the user experience. Also, its interactive interface makes it easier for both technical and non-technical users to navigate. Moreover, this utility supports all MBOX files of any email client.
    63
    If you want to know the most reliable tool convert their mailbox data. So, we suggest you to choose Corbett MBOX to PST Converter as its awesome solution and allows to export into multiple file formats such as PDF, TXT, EML, MBOX, PST and many more and also comes with user-friendly interface to easily use without depending on any technical guide.
