Results 1 to 12 of 12
    33
    How to back up Office365 emails into PST?
    If you want to back up your Microsoft Office 365 emails to PST format, here's how to do it. If you find yourself in this situation and looking for a professional approach, don't be confused consider utilizing the automated SameTools Cloud Backup Software. This software is available for any user, and it helps you to complete your task easily. You can easily backup Office 365 emails to another file format PST, MBOX & EML, etc. To start this the software first authenticates your Microsoft Office 365 login details and then converts email attachments to PST format. It, therefore, stops the users from creating any modifications during that point and creates one safe email recovery. It provides an understandable and simple user interface so that anyone can easily access the tool without any difficulties, and also supports all Windows OS versions.
    Read More:- https://www.sametools.com/cloud/backup/
    165
    With the help of the Office 365 Backup Tool, you can easily backup your Office 365 emails into PST format. It is an advanced utility for fast and effective backup of the entire Office 365 mailbox items. This tool can save Office 365 emails, calendars, contacts, and other mailbox items without any data loss. It allows you to backup multiple Office 365 accounts simultaneously. Also, this tool can migrate emails from Office 365 to Gmail, IMAP, AOL, and other email providers with attachments. It provides you the option to split the large resultant PST files into smaller PST files. Overall, it is the best solution to export Office 365 mailbox to PST without any hassle.
    119
    The Regain Office 365 to PST Converter Tool offers a straightforward way to back up emails. It’s user-friendly, supports exporting emails, contacts, and calendars, and allows you to select specific data for export. It ensures accurate PST file creation and provides a secure backup solution. Install the tool, log in with your Office 365 credentials, choose the mailboxes or folders to export, and set PST as the format. The tool will convert and save your emails to PST files efficiently.
    May 2022
    108
    Shoviv Office 365 Backup tool is a professional solution that helps the user in backup Office 365 mailboxes to PST files. It enables you to perform multiple mailbox backups simultaneously with no loss of data at all. It is possible to use the tool to back up primary mailboxes, archive mailboxes, and public folders. It is possible to create PST files of any size that is wanted and they can also be made password-protected. The software has a scheduler option to set time for the backup process on a daily, weekly, or monthly basis according to the user’s preference. In case of interruption of the backup process, the incremental backup ensures that it starts from the point of interruption to avoid over-backing up.
    Read also - Backup Microsoft 365 Mailboxes
    To get a professional solution, you can use an automated process by using the ToolsBaer IMAP Backup Tool. Using this tool, you can easily create a backup of your Gmail emails in Outlook PST format. It is the best solution to back up all the items in the Office 365 mailbox instantly. It exports Gmail to PST files with attachments. The software can save Gmail email along with calendar entries, contacts, and many more mailbox items which in itself is a huge achievement at the time of risking sensitive data from possible loss. The utility requires only login details of Office 365 to process all these tasks and give the best-oriented result from others. The software has magnificent functions for operations and supports all versions of Windows operating systems.
    82
    Kernel Office 365 Backup is a powerful tool designed to ensure the security and integrity of your Office 365 data. This reliable utility allows you to back up emails, calendars, contacts, and files from your Office 365 account, providing peace of mind that your important information is safe and easily retrievable.
    With its user-friendly interface, you can quickly select specific mailboxes or entire accounts for backup. The tool supports various output formats, including PST, EML, and MBOX, making it easy to restore or migrate your data to other platforms as needed.
    Additionally, this Office 365 backup and restore tool offers scheduling options for automatic backups, ensuring your data remains up to date without requiring manual intervention. With strong encryption and robust security features, you can trust that your backups are protected from unauthorized access.
    Sep 2024
    If you're looking for a tool to back up your Office 365 email files into PST format, the MigrateEmails Office 365 Migration Tool is a practical solution. It simplifies the process of backing up and migrating Microsoft 365 mailbox data to various email clients and file formats. The tool supports the export of Office 365 mailboxes, shared folders, and In-Place Archives, and allows you to restore your data using Outlook files like OST and PST.
    You can migrate data from multiple user mailboxes within Office 365 accounts and export emails to different formats or clients. It supports the simultaneous export of multiple PST or OST files, helping streamline the process. The tool offers features like email and task filters for selective data migration and also allows you to map selected files to appropriate user mailboxes.
    Additionally, the software provides a preview of mailbox items before migration and includes options to remove unnecessary emails for a more efficient backup. For added convenience, a CSV file can be used to specify user accounts during migration. The tool is compatible with all Windows versions.
    Dec 2024
    Users can use the Mailvita Backup Office 365 for Mac Software, which is the best way to back up Office 365 emails into PST without data loss. This application has a simple graphical user interface that makes it a simple and user-friendly solution for backing up entire Office 365 account data into PST, MSG, EML, EMLX, and MBOX file formats with basic technical understanding. Users can connect with any version of Microsoft Outlook, including 2021, 2019, 2016, 2013, 2010, 2007, 2003, and more. This application can simply support multiple data points from Office 365 accounts for backing up and exporting into PST file format. This software can work with multiple email clients Users can simply install this software on Mac 15, 14, 13, 12, 11, 10.15, 10.14, 10.13, 10.12, 10.11, and more operating systems. Users will get a free demo to examine features.
    75
    You may use MacMister Email Backup Software Mac & Windows to backup Office 365 emails to PST with attachments effortlessly. The tool is easy and friendly. Anyone can use it with ease and perform the process within seconds. Moreover, the application possesses many advanced features that allow users to backup Office 365 mailboxes according to the requirements. Download free demo now and backup first 25 Office 365 emails for free.
    Jun 2024
    16
    If you want to know how to convert an Office 365 mailbox to a PST file format, in this case, I recommend you try a professional tool like TrustVare IMAP Backup Software. It is designed to back up your Office 365 data, including its components like email, calendar, etc. With the help of this software, you can log in to your Office 365 account directly and start the backup in just a few steps. With the help of its interface, users can easily complete their backup process in just a few seconds and save the output as per their choice. It supports all Windows OS versions and offers a demo version to check if it is working.
    Feb 2025
    11
    If you are searching for an easy and safe way to back up Office 365 emails into PST format. Softaken Office 365 Backup Software is a wise choice With the use of this tool users can safely download and store their Office 365 with their complete mailbox and attachments in PST format. Depending on your needs you can choose which folders or the entire mailbox to back up. During the backup process, the program makes sure that the original email formatting and folder structure are maintained. Also, this tool supports all editions of Windows OS.
    68
    CloudMigration Office 365 Backup Tool is the best solution to backup office 365 to PST. It's an all-in-one utility that not only provides users with the ability to export Office 365 data but also provides import facility for PST/OST files to Office 365. Without totally relying on Office 365 or any other program, anyone can export Microsoft Office 365 email to PST or other supported formats easily. It's a safe and trusted process, especially for non-technical users.
    Follow the Software Working Steps to Export Office 365 Emails to PST:
    1. Open the Office 365 Backup Tool. Click on Backup and then Continue.
    2. Provide credentials and verify the login of the Office 365 account.
    3. Select source user accounts and the mailbox to migrate. Click Next.
    4. Observe the folders list in the preview panel > choose desired folders to export > Click Next.
    5. Move to the File Format option and select PST as the output format.
    6. To obtain accurate export results, choose the optional features that are offered. Click on Next.
    7. Provide the save location for the resulting PST file and then click on Convert.
