If you are searching for a way to do manual EML to PST conversion is not always safe for large file batches because it can be time-consuming. There is a risk of data loss or corruption. It can't properly convert large EML files to PST. So I recommend you use an efficient tool like DailySoft EML to PST Converter software. This tool is fast and completely safe. There is no need for technical knowledge because it has a user-friendly interface. It can convert single and multiple EML files into PST format in bulk easily. Also, it provides a preview facility to review EML emails before converting them into PST format. It is compatible with Outlook 2021, 2019, 2016, 2013, 2010, and others. You can try its features using its demo version and convert the first 25 emails without any cost.
visit here:https://www.dailysoft.org/eml/pst/
