Results 1 to 6 of 6
    81
    Affordable, Secre and Best OST to PST Converter Tool
    RecoveryFix OST to PST Converter is a robust, high-performance tool designed to convert OST files to PST format while maintaining data integrity and accuracy. This versatile software not only handles OST to PST conversions but also supports multiple other formats, including MBOX, PDF, JSON, and more. Users can effortlessly process single or multiple OST files, exporting emails, contacts, journals, tasks, and notes into Outlook-compatible PST files.
    Key Features:
    ✔ Multi-Format Conversion – Convert OST files to PST, MBOX, EML, EMLX, HTML, CSV, and MHTML.
    ✔ Cloud & Webmail Support – Seamlessly migrate OST data to over 15+ email platforms, including Office 365, Gmail, Thunderbird, and Yahoo Mail.
    ✔ Full Compatibility – Works with all versions of MS Outlook and Exchange Server, ensuring comprehensive OST file support.
    ✔ User-Friendly Interface – Designed for both technical and non-technical users, making conversions quick, easy, and hassle-free.
    177
    Make use of the OST to PST Converter tool for Outlook open OST file without Exchange in PST format on all macOS and Windows Operating Systems i.e., Win 11, 10, 8.1, 8, 7, XP, Vista, etc. The OST to PST Conversion Tool is an excellent utility that supports batch conversion from OST folder to PST format in one time process. First, you must try its free download version which allows you to save first 25 items from OST file to PST file format without cost. For Outlook open OST file without Exchange in PST format in bulk mode, then you need to go with the license key of the OST to PST Tool.
    21
    To convert OST files to PST without any tech knowledge, you can use the WholeClear OST to PST Converter. Users can use its advanced features that are designed for seamless email conversion. The tool allows users the efficiently convert OST files into PST format without any tech knowledge. It supports all OST files. It is a pure OST to PST Converter. Users can export OST files to PST with a few simple steps. Also, the utility offers a user-friendly interface, making it accessible for both non-experienced and experienced users. It is easily accessible to all Windows OS users. The software also has a free demo version.
    42
    To effortlessly convert an OST file into PST format, I would recommend using TrustVare OST to PST Converter. This tool offers the direct option to convert an OST file to PST format. This tool ensures all data integrity, email formatting, preserving attachments, and metadata throughout the migration process. Moreover, the PST file created by this software would be easily accessible and importable to all PST-supported email applications. It offers a free trial version and 24*7 tech support for users. Refer: https://www.trustvare.com/ost/pst/
    82
    It looks a like, you want an affordable and best OST to PST Converter, which can effortlessly convert OST file to PST format then you can make use of reliable EmailsGuru OST to PST Converter. It is specialized tool to convert OST file to PST format, saving emails, contacts, calendars, notes and all other items. Moreover, it recovers and convert corrupted, damaged or any size of OST file to PST without restrictions. Users can smoothly run this tool on Windows Operating System of any versions. Users can also use a free demo version before purchasing.
    54
    If you’re searching for the best OST to PST converter, the CloudMailMigration OST to PST Converter is a highly advanced and dependable tool designed to convert OST to PST format while ensuring complete data integrity and accuracy. It supports the conversion of OST files into multiple formats, including PST, MBOX, EML, EMLX, HTML, CSV, and MHTML, providing users with flexibility based on their specific needs. The software allows you to convert both single and multiple OST files at once. Additionally, it enables the smooth export of OST data—such as emails, contacts, calendars, tasks, and notes—to over 15 web-based and cloud email clients, including Office 365, Gmail, Thunderbird, and Yahoo Mail, ensuring a hassle-free data migration process.
    Steps to Convert OST to PST:
    1. Launch the CloudMailMigration OST to PST Converter Tool and browse for the OST files.
    2. Select and add the OST files you wish to convert to PST.
    3. Preview the details of the added OST files and click Next.
    4. Choose PST as the saving format from the drop-down menu.
    5. Select any additional features offered for a seamless conversion process.
    6. Click Convert to initiate the OST to PST conversion.
