Results 1 to 8 of 8
    Apr 2025
    2880, Zanker Road. California, USA
    71
    Best IMAP Bacup tool for Mac & Windows?
    If you want a reliable and advanced software tool for moving IMAP emails to different email clients or file formats, I would suggest the CloudMigration IMAP Backup Tool. This software helps you safely move mailboxes between email servers that support IMAP without losing any data. It works with all major email services like Gmail, Yahoo, Office 365, and others. Using this software, you can migrate one or an entire mailbox at once.
    Read More: Migrate Hostinger Email to Google Workspace
    28
    For Windows users, the MailsDaddy IMAP Backup Tool is one of the best solutions to backup IMAP email from Gmail, Yahoo, Outlook.com, and more. It exports data to formats like PST, MBOX, EML, etc., while preserving folder structure, attachments, and formatting.
    93
    IMAP is an email server that allows configuring email domains such as Gmail, Yahoo, Outlook, Thunderbird, and many email services. Therefore, users can simply and view all the emails of several email applications through the IMAP server by configuring it. In contrast, when you want to transfer emails from IMAP to any other email service or file format, it gets very monotonous. Hence, the MacSonik IMAP Backup Tool is the best software available to backup IMAP emails to your PC. It can backup your IMAP mailbox into various formats while not hurting the data.
    - You can Import IMAP Emails to Gmail, Office 365, and more file formats.
    - It can Migrate IMAP Emails to Different Email Clients.
    - The software can Convert & Download Multiple IMAP emails at the same time.
    - It Prevents the duplication of Duplicate Emails in the backup.
    - Backup your IMAP Emails from the IMAP Server with all the Attachments securely.
    - Option to Skip Saving the Attachments from the backup process.
    - With a Built in Mail Filter feature to backup selective emails.
    - The Free Up Server Space feature creates additional space by deleting the backed up emails from the server.
    May 2022
    142
    If you’re on Windows and need a reliable IMAP backup solution, Shoviv IMAP Backup Tool stands out as one of the best picks. It lets you export mailboxes from any IMAP-enabled server to PST, MBOX, EML, MSG, preserves folder structure, attachments and metadata, and supports multiple accounts in one go.
    It also offers a “delta backup” feature — so after the first full backup, you can download only new emails in later runs.
    60
    To export IMAP emails to other file formats, webmail apps, you can utilize the CubexSoft IMAP Backup tool for Mac & Windows that can simply transfer IMAP files to other file formats, webmail apps. It is simple to access for everyone. The tool supports multiple IMAP accounts at once. Using the tool, you can export IMAP data to PST, PDF, MBOX, IMAP Server, EML, EMLx, Gmail, Office 365, Exchange Server, Outlook.com, Yahoo Mail, etc. https://www.cubexsoft.com/blog/impor...to-office-365/
    112
    If you are looking for the best IMAP backup tool for Mac & Windows, it’s important to choose a solution based on your system compatibility. Since you specifically want to suggest Softaken Gmail Backup Tool, here’s a well-structured answer, keeping in mind that it supports only Windows. The best IMAP backup solution depends on your operating system. It is the best utility that allows users to backup Gmail emails and other IMAP-enabled accounts into multiple formats like PST, MBOX, EML, and MSG. The software ensures complete data safety, maintains folder structure, and supports selective backup options. It is designed with a simple interface, making it suitable for both technical and non-technical users. It will run on all Windows OS versions like 11, 10, 8.1, 8, and 7 without downloading any application.
    Visit here: https://www.softaken.com/gmail-backup-pro
    117
    If you are searching for a best solution to backup IMAP mailboxes, then make use of MacMister IMAP Backup Tool Mac & Windows. With the help of the tool, users can save IMAP-supported email client emails into 15+ saving options. Its GUI is user-friendly, cost-effective, and advanced. Both technical and novice users can utilize the app without trouble and backup IMAP emails with ease. Moreover, MacMister IMAP Backup Tool Mac & Windows supports 15+ saving types to backup IMAP mailboxes such as PST, PDF, MSG, EML, HTML, DOC, IMAP, Yahoo Mail, Office 365, and more. Download its free demo to explore the detailed software processing.
    Apr 2023
    112
    If you are searching for solution to know about how to save IMAP files into other file format & webmail apps, used the IMAP Migration Tool for Mac & Windows that is a versatile and user-friendly software designed to simplify email backup and migration tasks on both Mac and Windows platforms. This powerful IMAP Converter tool offers seamless support for various IMAP email clients, including Gmail, Yahoo, Outlook, and more, making it an ideal choice for users seeking a unified solution for safeguarding their valuable email data. With its intuitive interface and advanced features, the CubexSoft IMAP Backup Tool allows users to effortlessly create backups of their entire mailbox, ensuring data security and minimizing the risk of accidental loss. Whether you need to back up your emails locally or migrate to a new email platform, this tool provides a reliable and efficient solution to meet your needs, making email management and protection a hassle-free experience. https://www.cubexsoft.com/blog/impor...to-office-365/
