MailConverterTools PST File Viewer is readily accessible for personal use. This brilliant software supports users in scanning and opening damaged PST files. You may access calendars, notebooks, contacts, emails, and more using the software. With the help of this software, users can convert PST to HTML, PDF, MBOX, and PST. No File Size Limitation is a crucial feature that allows you to load and read even large PST files without any problems. Your PST file can contain alignment issues if it was recovered from damaged media. While scanning the file, this software may automatically identify and correct those mistakes, allowing you to access your data without any problems. The software offers three scanning modes based on file damage. Standard mode is for minor corruption, Advanced mode handles moderate corruption, and Deep mode is used for severely corrupted PST files. Apart from this, the software is highly compatible with all major versions of Windows Operating Systems.
